Entry Point Not Found, But Solved
Hello again guys, the problem with the entry point was solved (THANKS TO YOU GUYS)and I should tell you what happened because you might receive another inquiry like this in the future. Following instructions from you, and I'm not seeing your names as I type the message but you know who you are, I was able to track down the offensive plug-in.
I uninstalled Waves Gold Bundle and ProTools once more but this time I went to Program Files\Digidesign\DAE\plugins folder and I found that 4 plugin files were not removed: Two of them were WaveShell-DAE 3.5.dpm and WaveShell-DAE 3.5.dpm.rsr but these I know were not to blame because I had them removed the last time I wrote to you and I still had the problem. The other two were from the MOOG Modular System demo I was trying some time ago (YOU WARNED ME ABOUT THIS ONE)and by some reason stayed there when I removed the demo. I already wrote to Waves and explain to them this problem so they can help others that may have a similar issue. MILLIONS OF THANKS TO ALL OF YOU P.S.: Now that I saw your names I want to give special thanks to: Rail Jon Rogut Tele_Player QuickDraw and Freakofnature |
HELP ME PLEASE Entry Point Not Found????? | Gonkboy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 07-22-2009 04:12 PM |
ProToolsLE.exe - Entry Point Not Found | jdmac | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 04-01-2008 06:28 PM |
pro tools. exe- entry point not found. HELP!!! | syren loc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 07-10-2007 11:08 AM |
Pro tool le.exe - entry point is not found??? | raji57 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 12-14-2005 01:14 AM |
Error: Entry Point Not Found | Ditherman23 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 07-10-2005 08:16 AM |
