Tips for buying a 2nd used 11R
Fellow locally is selling used 11R at fair price without Pro Tools.
Serial Number: Dfdkb33800373b Did the "D" series have issues? Since I own ProTools and an 11R already, will I be able to transfer ownership of the used one to me without the Pro Tools disks that came with the used unit? It has the latest firmware and Expansion pack installed.
[SIZE="2"][COLOR="Blue"]Intel Haswell-E Processors 3.3GHz Core i7-5820K 6-Core; Memory - DDR4: 16GB DDR4-2400 Quad Channel (4 x 4GB); Primary Drive (OS): 240GB SSD SATA3; Secondary Drive (Audio): 2TB 7200 rpm SATA2; Graphic Card: 1GB (HD5450) Dual Display Graphics Card; Optical Drive: 22x CD/DVD Dual Layer Burner; Windows 10 64-bit; PT 12.5; Studio One Pro 3.2; Cubase Pro 8.5; REAPER; MixBus 3 |
Re: Tips for buying a 2nd used 11R
You should be able to transfer ownership if you want, but since it's a used unit it doesn't really do anything for you unless there is some warranty left on the unit.
You won't see the hardware registered to you in your Avid account either, but Avid will have the records. Just use the form http://avid.force.com/pkb/articles/FAQ/en363631 http://avid.force.com/pkb/servlet/fi...ent_1__Body__s
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
If my original 11R were to die for some reason, and I swapped it with the used one, would it work with my PT?
Yes, if you have old PT LE then it will work with the interface, any modern version of Pro Tools (9, 10, 11, 12) is licensed by an iLok so will work with any compatible interface, so will work as well.
I got another one also, recently!!!! Wonderful units and now I don't have to take it out of my room/rack anymore!!!
Tips for buying a used C24 | Raggi | ICON & C|24 | 7 | 07-25-2014 11:19 AM |
Tips on Buying a Used Pro Control (shipping weight etc) | DaveSB | ProControl, Control|24, Command|8 | 3 | 04-29-2007 08:35 AM |
tips for buying DVD player with discrete audio out | mtung | Post - Surround - Video | 6 | 03-13-2006 12:04 PM |
Buying New Computer...I Some Need Tips..... | sethbrand | Pro Tools M-Powered (Win) | 9 | 03-13-2006 08:50 AM |
Tips on buying outboard gear under 500€/$ | Finnish | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 08-06-2005 04:08 PM |
