Old 03-16-2012, 01:50 PM
dmoffitt dmoffitt is offline
Default Cannot hear playback while in record mode.
Hi experts,
I am simply doing voice recording. One dry track no bells or whistles; however, when I came in today to try and punch record some audio. I am not getting anything in my headphones while in record mode.
I am able to hear perfectly in edit mode, and all other audio formats - music, video, etc. routed through interface is heard normally. I don't believe I've hit any buttons or changed any settings for this to stop working over night.
What I've done so far:
reboot (several times)
updated to LE 8.0.5 from 8.0.3
Went through optimization document and configured accordingly
tested from session directly on local hard drive as well as external drive both I was able to hear track during edit mode but not during record mode.
Setup:
Mac Mini
OS X 10.6.8
2.26 GHz Intel Core
2GB memory
ProTools LE 8.0.5
What are my next steps. From your knowledge is this a ProTools or audio interface issue?
Thanks in advance for any help or guidance.
Old 03-16-2012, 01:55 PM
Craig F Craig F is offline
Default Re: Cannot hear playback while in record mode.
what interface are you using?
Thank you,
Craig
Old 03-16-2012, 02:11 PM
The Dougfather The Dougfather is offline
Are you talking about not hearing the pre-roll audio prior to a punch-in?
Try toggling between input only and auto-input monitoring, Option-K.
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D
iCON Photography
Old 03-16-2012, 02:17 PM
Whoops, sorry.
mbox mini (g2)
Old 03-16-2012, 02:21 PM
Thanks for a response Dougfather but still not working.
I've also switched out headphones and headphone jack adapters. It just seems so weird to me that it would just stop working.
Old 03-16-2012, 02:27 PM
livetvop livetvop is offline
you have to make sure the output of the track is set to the audio interface your headphones or speakers are plugged into and not a bus.
Old 03-16-2012, 02:33 PM
Check.
Output of track is set correctly. I can hear playback of track during edit just fine.
Hear a source while in record mode but not recording sciascia Pro Tools M-Powered (Mac) 2 06-16-2012 03:26 PM
BFD Light Triggers a loop when in Playback or Record mode with the Metronome Enabled NYKeys Virtual Instruments 3 04-09-2009 05:40 PM
Can't enter record mode while during playback jtarbutn 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-25-2007 03:17 PM
Can't hear guitar on playback only in record..... northwinds Pro Tools M-Powered (Win) 1 10-29-2007 07:39 AM
Cant hear record enabled track during playback michaiel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-19-2005 01:59 PM
