Audio Files format swapping?
Hi:
I'm working on an interesting project in PT. It was originally recorded in Cubase for PC. We are connecting a PC and our Mac in a network, copying the original audio files in WAV format, opening gthem in PT and mixing in my favorite program (PT, of course). I was creating my original PT sessions using SDII Audio File format, and the system worked fine until I reached a complex song, so I realized I should have started creating the sessions using WAV audio format from the very beginning, as I'm doing now. The question is: How can I change the Audio File format of an existing session from SDII to WAV (which is the real audio format the session is using, by the way)? THanks Alex [email protected]
MacBook Pro 2.16 GHz Intel Core Duo, 2 GB of RAM, OS 10.4.11, PT 7.3.1 |
Re: Audio Files format swapping?
Audio Ease do Barbabatch which is a fantastic batch file conversion utility if you need to do many conversions -
http://www.audioease.com/Pages/Barba...BarbaMain.html
Stuff, mostly |
Create a new session w/WAV format. Then use the File menu's "Import Tracks" command. (Check out the "audio media options".
Hi Alex,
You should open your existing SDII session and choose File -> "Save session copy in". In the dialog box you should choose WAV and "copy all audio files". Then you can start working on your new WAV session. Hope it helps Yaro
www.cmy.pl |
Problem bouncing multichannel files - format changes | dubbydougie | Pro Tools TDM Systems (Mac) | 2 | 03-05-2011 12:08 PM |
Converting PTS files to WAV or another format | Valkhorn | Pro Tools TDM Systems (Mac) | 2 | 11-17-2007 07:23 PM |
session files to mp3 format? | elv1s1sal1ve | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 07-05-2005 08:57 AM |
Bounced files - Invalid file format | jshearer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 16 | 06-04-2003 06:20 AM |
Making RealMedia files into quicktime format for use in PT.. Is it possible? | Mt.Everest | Pro Tools TDM Systems (Mac) | 1 | 06-29-2001 03:25 AM |
