Old 09-26-2007, 03:20 PM
separatist separatist is offline
Default Issue with digi002 and focusrite octopre LE
Hey all! I recently bought a Focusrite Octopre LE interface with the optional ADAT I/O feature so I could have some more inputs for recording... But i cant seem to get any signal from the Focusrite into the 002, any ideas what it could be and how i could fix it?
Thanks
Sam
Old 09-26-2007, 07:16 PM
Default Re: Issue with digi002 and focusrite octopre LE
You need to set the optical output to OPTICAL=ADAT. In hardware setup, choose SYNC to ADAT(or you will get clicks and pops in your recordings). Attach a lightpipe "cable" from the Octopre ADAT output to the 002 ADAT input. Go to the I/O setup window and see if your list of inputs shows 9-13. If not, select NEW PATH and build the inputs yourself.
Old 09-28-2007, 05:17 PM
hmmm... I havent managed to get it to work yet, when I open Hardware Setup the only thing seemingly available to change is the Digital Input section, and out of the two options available for that I have "RCA = S/PDIF, Optical = ADAT" selected, as opposed to "Optical = S/PDIF, RCA = OFF"... When i go to the I/O setup its got the whole 18 channels available in a 002 displayed, 8 of which are labeled 'optical'... I'm still not getting any signal from the OctoPre to the computer. I've got the lightpipe cables connected and all, is there anything else that could be causing the trouble?
Thanks
Sam
Old 09-29-2007, 10:26 AM
Naagzh Naagzh is offline
Sounds like something's up with the Octopre. Under the "digital" part, are your settings correct? What lights are lit?
And what are you connecting to the Octopre? Mic? Guitar?
002R PT7.3.1
MacBook Pro 2.33
OS 10.4.8
Old 09-29-2007, 01:55 PM
KamaSutra77 KamaSutra77 is offline
I had the same issue/trouble getting my Octane pre to work into my new 003. What I found I needed to do was set the pre itelf to send a sync signal, and have the PT box sync to that to avoid hiccups.
Huh?
Digi002/Focusrite Octopre tricyclerocks macOS 3 03-22-2012 05:52 PM
003R+ rack with octopre VS Focusrite Octopre x2 through M-audio Lightbridge Sweepxcore General Discussion 12 05-24-2009 06:44 PM
pitch problems with focusrite octopre and Digi002 larb 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-18-2008 07:20 AM
Focusrite OctoPre LE Edson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 04-10-2007 08:01 AM
Focusrite OctoPre binaural42 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-03-2005 02:39 AM
