Pro tool le.exe - entry point is not found???
this is the response i am getting when i try to open a recently purchased pro tools. any help... i've been on hold all day with no response, not really happy buying software that wont install and not recieving assistance
Re: Pro tool le.exe - entry point is not found???
There are a few topics in the Answerbase.
The first in the list says: Quote:
What Digi hardware? Which version of PTLE? A system summary: XP SP1 or SP2 processor/motherboard/chipset Hard drives and ram |
You have a DAE mismatch or incompatible plug-ins. Uninstall Pro Tools and the drivers and reinstall.. then reinstall all your plug-ins with the latest compatible versions.
Rail
Hey!
I just went through the same issue. Try this: watch the text above the little scrolling bar as Pro Tools is loading - when it freezes with that error message make a note of what plug in it got stuck at and then remove that one from your plugins folder. See if you progress further after that. Of course, if you get multiple freezes as Rail says it might be worth removing everything including plugs and starting again. I also found that I had to make sure that the plugs were the same in both the Digidesign folder AND the Common Files/Digidesign folder - sometimes plugs seem to get installed in one or the other or both - hmmm! Cheers Doogz |
I also had this error when I checked all the boxes on install, like DV Toolkit, translator, etc. When I uninstalled and reinstalled with only the stuff I needed, the error went away.
As far as plugs went, I recall seeing Vocalign.
002R Win7, no PT GigaByte 970A-UD3/AMD FX(tm)-8120 8GB DIMM DDR3 AMD Radeon HD 6570 2 WDC WD10EURX-63FH1Y0 www.soundchasm.com |
HELP ME PLEASE Entry Point Not Found????? | Gonkboy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 07-22-2009 04:12 PM |
ProToolsLE.exe - Entry Point Not Found | jdmac | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 04-01-2008 06:28 PM |
pro tools. exe- entry point not found. HELP!!! | syren loc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 07-10-2007 11:08 AM |
Error: Entry Point Not Found | Ditherman23 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 07-10-2005 08:16 AM |
Entry Point Not Found, But Solved | Armando Romeu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 06-30-2003 02:58 PM |
