Old 01-30-2024, 11:23 PM
skylar_battles skylar_battles is offline
Default "Change the marker ruler selection" shortcut?
"Change the marker ruler selection" is performed by Command+Option+Left/Right Arrow according to the Pro Tools Shortcuts Guide.
What is this shortcut meant to do and between which rulers?
When I try to test it out with multiple main marker rulers in view and track markers as well, it just starts playback as it "conflicts" with "Play by pre- and post-roll value through selection start/end" which is assigned to the same keystrokes.
Anyone here know? Thanks :)
Pro Tools Ultimate 2024.3.1
MacBook Pro 16"
Apple M2 Pro with 12‑core CPU, 19‑core GPU, 16‑core Neural Engine
32 GB unified memory
1TB SSD storage
Ventura 13.6.4
Old 01-31-2024, 12:33 AM
BScout BScout is offline
Default Re: "Change the marker ruler selection" shortcut?
It's supposed to change the selection (target) main marker ruler. The one you see the red focus on so when you hit enter, that becomes the one that gets the marker.
However, they overlapped the shortcut keys. If you wipe out the other one (in Pro Tools's keyboard shortcuts settings), you'll see it work.
Old 01-31-2024, 01:13 PM
Meaning that it is a shortcut unrelated to track markers?
Is it similar to how Shift [ or ] moves the track marker target but instead between the main marker ruler and markers 2 for example? I don’t know why the default assignment is a conflict with an older shortcut. It just means probably it won’t get used to be honest.
Could you attach a video of what it does? Still uncertain. Thanks!
MacBook Pro 16"
1TB SSD storage
Ventura 13.6.4
New marker ruler keyboard shortcut? Scott G Post - Surround - Video 3 09-25-2023 12:31 PM
Keyboard Shortcut for "Track List", "MIDI Editor Pane", and "Clip List" EdgarRothermich Pro Tools 12 2 10-04-2017 02:18 PM
Can't change external volume from "T" to "R" in workspace. [SOLVED] take77 Pro Tools 12 0 04-09-2016 04:52 PM
"Pinning" the tempo ruler / keeping regions in time when moving geelo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-17-2016 11:08 AM
Alt-Shortcut to reach "Edit" > "Automation" > joachim Windows 0 10-13-2014 08:14 AM
