Pro Tools 12.2023... Midi Sustain doesn't always turn off when stopping Transport
Doesn't happen all the time but enough to make it a nuisance.
Sometimes I'll stop a song and the piano sustain (cc64) is still activated making the last notes played continue to sound. Also happens occasionally with softsynths. Any thoughts on this? |
Re: Pro Tools 12.2023... Midi Sustain doesn't always turn off when stopping Transport
Is sounds to me like like "stuck" MIDI notes (when the note off message is never received) causing infinite sustain, until user intervention. In that case, you can hit: Command Shift Period send the "All MIDI notes off" message. Sometimes you have to Command Control click the problematic plugin twice to make it inactive and active again. The only reason that I'd believe the sustain pedal is getting stuck is if you open that lane of data and see the issue presented in the automation data. Otherwise I'd assume stuck MIDI notes.
Pro Tools Ultimate 2024.3.1 MacBook Pro 16" Apple M2 Pro with 12‑core CPU, 19‑core GPU, 16‑core Neural Engine 32 GB unified memory 1TB SSD storage Ventura 13.6.4 |
This happens to me when I have midi merge engaged on an initial recording pass. Behavior is better with it off.
But, I otherwise agree. Too many stuck/hanging notes (especially with some Kontakt instruments) and the "All Notes Off" command only works if a track is in record (which only works for one at a time).
Kerry Smith http://apothekerry.com Mac Studio Ultra : 128GB RAM : Ventura 13.6 : Carbon : PT Ultimate 2023.12 : S1 : Metagrid Pro |
"Sustain" Doesn't work in Midi Editor Pro Tools 12 | feikamoh | Pro Tools 12 | 7 | 08-24-2017 10:26 PM |
Kore player stopping transport controls | paulwilks | Virtual Instruments | 1 | 10-10-2011 06:26 AM |
Sustain info doesn't follow moved midi | pianosound | MIDI | 2 | 11-22-2008 11:16 PM |
Transport Window inconsistent stopping playback | beverlysfield | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 10-18-2005 11:18 AM |
Stopping playback returns transport to zero? | TimInVan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 02-13-2002 04:49 PM |
