Copy Special: All Automation (except volume & pan)
Hey all,
Looking for some advice on copy/pasting multiple plugin automations across tracks and clips. I have a dialog group of 24 tracks with the same signal chain on every channel. I have checkerboarded clips across multiple tracks. Unfortunately for me I premixed levels before automating plugins, using copy/paste all automation also copies across volume and pan. Is there a preference or workflow I'm missing that will allow you to use Copy Special without volume and pan from one clip on one track, to another clip on another track? Or simply, is there a quick way I can copy all plugin automation on a clip in a track, to another clip in a different track? Any help is appreciated,
Pro Tools 2024.3.0|Perpetual MTRX Studio HDX1 Sync-X S3 Dock Mac Mini 2018 - 3.2GHz i7 6-core macOS 13.6 RAM 64GB DDR4 GPU AMD 6900XT 16GB Monitor LG 32UL950-W |
Re: Copy Special: All Automation (except volume & pan)
You could try to duplicate the existing tracks as a way to save the pan and volume information. Then copy / paste the plug in automation including the volume and pan, once that is done copy back only the volume and pan automation from the saved duplicate track versions. From there you should have what you need. Plugin automation from one set of tracks and volume and pan automation from another set of tracks. Might be another way. Hope this help. Cheers Bruno |
https://www.soundonsound.com/techniq...mation-grab-go These, in combination of enabling or disabling automation parameters, will accomplish what youre looking for. |
Will copy just that.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
Heya! Thanks for this.
Unfortunately copy special: plugin automation will only copy automation lanes that are visible, which means you have to open every lane with automation data for each plugin on a channel.
Capture/Punch Capture works with currently writing automation and on a per-channel basis as far as I'm aware, which means you can't just click on a clip capture and punch that to another clip on another track and without running playback. Unless I'm missing something, open to being schooled.
Scott Gatte๑o |
Ah, yes. That's true. Wish I could be more help.
Scott Gatte๑o |
There is a convoluted way to use capture / punch capture, between different tracks.
I was unsure in original post if you were looking to copy static or dynamic plugin automation. If it is a static setting that you want. You can copy a small portion of the original region from track A to empty space on track B (with all automation) and then use 'option+shift capture' (disable vol and pan in automation select panel first) to load into the capture buffer the settings from the original region from track A(which now sits on track B). Now you can select a range on track B and option+Shift punch capture then write automation to all selected, to write the capture buffer to a range. This also works across multiple tracks. I usually use this also with preview. So I will capture the setting then option+shift punch capture with preview mode on before writing the range. Easy to do difficult to write. Hope this helps Cheers Bruno |
Copy Special Automation/Panorama , undocumented ? | joachim | Post - Surround - Video | 5 | 05-09-2012 02:40 AM |
Copy special Plug-in automation shortcut | simonyeah | Post - Surround - Video | 1 | 07-12-2010 04:41 AM |
Copy special>plug-in automation is greyed out | Studio Studio | Pro Tools TDM Systems (Mac) | 6 | 05-12-2010 01:36 PM |
Copy Special: All Automation Quirk / Weird | Nathan W. | Pro Tools TDM Systems (Mac) | 3 | 02-07-2010 02:00 PM |
SWOD on copy special automation 7.3.1cs4 | woodsdenis | Pro Tools TDM Systems (Mac) | 2 | 08-24-2007 02:25 AM |
