Audio clips' real-time properties?
Is there anything similar to Midi real-time properties for audio clips? (I'm thinking of delay or negative delay)
MUSICNET STUDIO Via Puini, 97 57128 Livorno ITALY |
Re: Audio clips' real-time properties?
Hmmm...negative delay? Please explain. Are you thinking about a timing change from the original timestamp? I doubt that is possible(but I could be wrong). Or are you talking about expanding things that Clip Effects has to offer? If this is it, start with some tutorials(youtube) on using Clip Effects. Otherwise, maybe if you describe what you want in clearer terms, someone may have an idea.
You can do a manual offset with the delay compensation view in the mix window.
https://www.dropbox.com/s/kot3rw950mqluwf/K.gif?dl=0
Maybe Spot Mode?
Yes Spot Mode works fine
Thank you
Repeating Real Time Properties Bug With 12.8.3 | Jon_Atkinson | Pro Tools 12 | 3 | 01-24-2018 08:51 AM |
midi real time properties issues | End Over End | Windows | 0 | 03-14-2014 11:38 AM |
Real Time properties not working | Shifted Music | macOS | 3 | 10-30-2013 07:19 AM |
Question about midi real-time properties | mahag | macOS | 2 | 05-05-2013 11:54 AM |
Real-Time Properties | filosofem | MIDI | 9 | 06-24-2007 07:35 PM |
