Old 09-30-2022, 09:02 AM
Sparky1 Sparky1 is offline
Default "Commit" or "Bounce" Non ARA 2 Melodyne Track?
Hello
Using Melodyne (Non ARA 2 Version) as an insert on a track.
Does "Commit" and "Bounce" the track give the same processed result?
Thanks,
Sparky
Old 09-30-2022, 01:14 PM
nednednerb's Avatar
nednednerb nednednerb is offline
Default Re: "Commit" or "Bounce" Non ARA 2 Melodyne Track?
IF
Melodyne is last insert, NO automation on fader or panners,
THEN THEORETICALLY
Commit makes what gets bounced.
HOWEVER
When the fader is moved after the melodyne, commit would have the audio only up to that point.
So if no changes to the signal occur after the point where commit occurs, then it's the same. Have to consider for instance any BUS or Master processing.
In other words, yes and no it depends.
___
>> me: nednednerB //
||main gig: editing audio voiceovers & testing software | 2nd gig: music software tutoring | hobby: electronic music //
||software: Sonoma 14.2 | PT Studio 2023.12 | Ableton Live 11 | iZotope RX, Ozone, Neutron | Arturia Pigments | Auto-Tune | Dubler2 //
||system: iMac (Retina 5K, 27", 2020) 10-Core-i9 | 128GB-DDR4 | 5700-XT-16GB | OWC Thunderbolt Hub and Thunderbolt 3 Dock //
||devices: RME Babyface Pro FS | Focusrite Clarett 2Pre | some AT mics | SM58 | Ableton Push 2 | Sennheiser HD 600 HP // Onkyo TX-8220 SR
||automation: SoundFlow | Stream Deck+ | Keyboard Maestro | SteerMouse | MacOS Shortcuts //
Last edited by nednednerb; 09-30-2022 at 01:16 PM. Reason: add note about BUS processing
Old 09-30-2022, 01:55 PM
Methods vary, but mine(for non-ARA) is to always use Melodyne in the first insert slot>make edits as desired>right-click on the Melodyne Plugin and select "Commit up to this Plugin" and select "Do Nothing" to the original track. Once the commit finishes and creates its new ".cm" track, I move the printed audio back to the original track, but to a new Playlist(so the original un-edited audio is kept handy, but hidden)and make the Melodyne Plugin inactive(or remove). Delete the (now empty) ".cm" track and get on with whatever's next
Old 09-30-2022, 05:48 PM
Originally Posted by nednednerb View Post
IF
THEN THEORETICALLY
HOWEVER
Interesting... I did not know most of this...
Thank you...
Sparky
Old 09-30-2022, 05:51 PM
I typically place Melodyne on my first insert as well...
I like the idea of "commit up to this plugin"
I think I'll start moving the committed track up to the original track in a new playlist... good idea!
Thanks,
Sparky
Old 09-30-2022, 10:34 PM
Dizzi45Z Dizzi45Z is offline
This is exactly what I do. I really wish there was an option to "commit to new playlist." In this case, it would make inactive all plugins up to the point you commit to, make a new playlist and put the processed audio on the playlist.
recording.guru : FREE Pro Tools Tips and 19 Video Basic Training Course
Pro Tools HDX 2023.9
Mac Pro 7,1 3.2 GHz 16-Core Xeon W
160 GB RAM
macOS 11.7.4
Noisebox Studios -Utah Recording Studio
Old 09-30-2022, 10:52 PM
nednednerb's Avatar
Maybe this is a case where SoundFlow automation would be useful... I'm more and more interested in my own macros for features that ARE there for one button after encoding the specific keyboard shortcuts in sequence, first..!
___
>> me: nednednerB //
What good is "Save Copy In..." options "Session Plug-in Settings Folder" and "Root"? ZerglingPhilosophy Getting Started 1 09-02-2022 03:43 PM
"Digidesign Midi I/О" in "ProTools 10HD" in "OSX Maverics" electra1006 MIDI 0 06-18-2018 05:46 AM
Keyboard Shortcut for "Track List", "MIDI Editor Pane", and "Clip List" EdgarRothermich Pro Tools 12 2 10-04-2017 02:18 PM
"Bounce To Disk" Track is "Lower in Volume" LSNY Pro Tools 12 18 06-05-2017 08:45 PM
If I "Remove Unused Regions" after "Consolidate", track won't play? el biciclista Pro Tools TDM Systems (Mac) 10 04-02-2003 10:17 AM
