Old 04-28-2022, 03:05 PM
Ben Jenssen's Avatar
Default "Can't locate PT authorization" PT 2020.12 and iLok USB Key
I have, and I'm on v 2020.12. Two times the last couple of days, I've come back to my computer and the error is like: "can't locate PT authorization. Insert ilok now or save and quit." Ilok is inserted all the time. I save and quit, relaunch and everything is fine. I got rid of iLok Cloud recently just to avoid these kinds of episodes. I've kinda figured there was a thing with Avid changing things with 2022 and reconfiguring licenses in some way, but that thinking comes from a year of using ilok cloud and relying on online connection - ilok key with license should never have 'dropouts' or glitches, right? that's the whole point.
Last edited by jeffro; 05-18-2022 at 10:30 AM. Reason: Broken out from thread specific to v2022.4
Old 04-28-2022, 04:07 PM
jeffro's Avatar
jeffro jeffro is offline
Default Re: 2022.4/iLok Pace issue?
Originally Posted by Ben Jenssen View Post
...Two times the last couple of days, I've come back to my computer and the error is like: "can't locate PT authorization. Insert ilok now or save and quit." Ilok is inserted all the time...
What version of iLM?
linkedin
Old 04-28-2022, 04:14 PM
I updated it 2 or 3 weeks ago.
Old 04-28-2022, 07:54 PM
Did you see this on your system? I just updated iLM to 5.5.2 this morning and it left my Cloud Session in Managed mode.
What is this "automatic/manual managed mode" that you speak of?
(I thought that selecting "Close ilok cloud session", and transferring all licenses to the dongle would turn off the ilok cloud thing. is there more?)
Old 04-28-2022, 10:29 PM
BScout BScout is offline
Click on the iLok cloud. Open/activate it. Then look to the right column and do “show details” (much like you’d look at TLC protection on a normal iLok).
Then look at the top right corner and it will show the mode. Click there and you can switch modes.
After you have it in manual, log the cloud out/close the iLok cloud session.
Old 04-28-2022, 10:43 PM
Originally Posted by BScout View Post
Click on the iLok cloud. Open/activate it. The look to the right column and do “show details” (much like you’d look at TLC protection on a normal iLok).
Thanks.
iLok cloud details says: status closed, mode managed.
I don't see any switch modes button, but that's ok.
Added: Ok, if I click the "open cloud session", which is sorta to the top right on screen, ilok cloud is activated and I get an option to 'automate' it managementally… silly. I just close the damned thing.
Old 05-11-2022, 03:21 AM
It's been two weeks now, and it has not happened again. I'm not shure if my two incidents really was the same issue at all, and the problem is with 2022.4, or perhaps the fact that I moved my ilok from usb3 port on the Mini to a usb1 port on an older wired apple extended keyboard. IDK.
Old 05-11-2022, 10:14 AM
jeffro's Avatar
Thanks for your status update. Sounds like a different issue in that all other reports are with 2022.4.
linkedin
"Unable to Locate Hardware" error and iLok issue amedouce Getting Started 2 05-14-2018 07:14 PM
Ilok drama! "Authorization exception" error Kristo Kotkas VENUE Live Sound Systems 6 12-20-2017 03:56 PM
"Missing iLok authorization" error for MAC USERS jonopeters macOS 53 10-25-2016 12:47 PM
"Error, missing ILok authorization for "Pro Tools 10". johkav macOS 4 09-10-2012 08:13 AM
Random Error, missing iLok authorization for "Pro Tools 9" ktuulu Windows 52 04-05-2012 09:53 PM
