Pro tools no longer makes bus sub paths automatically
When creating a send or output to a new stereo track, I noticed that protools no longer automatically makes mono sub paths to the stereo bus path. Is this a pref? It’s annoying when you want to use that bus path as a key input for something else or other situations when the mono sub path is useful. I noticed this yesterday when working on a clients rig that was on 2021.12. My rig is 2020.x and I don’t have this behavior. Is this a new pref? Or is this just how it is now. Glad I’ve waited to update as this would disrupt my workflow a lot.
Re: Pro tools no longer makes bus sub paths automatically
Just check the "Auto-create sub-paths" checkbox in the new bus dialog.
http://www.richbreen.com ---------------------------------------- Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6 |
This applies to the busses that are created from making a send or output of a track to a new track, not creating a bus in the iO setup. And I went to the io setup and clicked that to see if it made a difference. No dice.
Weird, but the only way I found to do this was to be in the Output section of the I/O - Highlight the first stereo out - stereo 1+2 - and down at the bottom of the window click "Create New Sub Path" - Select 2 for the number of sub paths and voila! It's there. Bummer is, you have to do that for each stereo pair - 32 in my case. But it worked. Very very
Mac Studio Ultra / 128 RAM/2TB HD / Avid HDX Chassis / 2 X Sonnet Echo Dual NVMe Thunderbolt Docks w Samsung 970 EVO Plus (6TB) / Avid C24 / Avid 16X16 I/O Analog / Lynx Aurora 16/16 1/O Analog / Dangerous 2 Bus / Benchmark ADC1 www.glasswing.com www.richardsales.com |
I just came across this as well. You don't have to do it for each instance though. Just select the amount of busses you want like tracks on the left of the dialogue box.
Mac Mini M1 16 GB OS 12.7.4 PT 2024.3.1 |
Bounce Mix offline makes longer bounce than 'online' | GregX | Pro Tools | 2 | 11-17-2021 12:42 PM |
Some bus paths could not be mapped to their previous output paths. | Kbiastre | Pro Tools 2019 | 4 | 02-02-2020 03:31 PM |
Stereo HD Native Low Latency monitor paths are a no go with active surround paths? | vieris | Pro Tools 12 | 3 | 07-27-2015 06:07 PM |
CoreAudio Driver no longer launches "automatically" | swavek | macOS | 9 | 11-05-2013 05:53 AM |
Question about Sub Paths and Main paths. | oulablank | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-15-2009 12:15 PM |
