Old 02-19-2011, 12:08 PM
entoine entoine is offline
Default How to have Quick controls on Mc mix from cubase 6 ?
I'm on Cubase 6 (32bits version), on PC with an euphonix MC mix (os : win7 64)
I can't manage to have the quick controls on my MC mix?
in péripherals configuration there is a tab for Quick Controls where I can assign an "euphonix eumidi" input and output...
but I can't find how to access it on the mc mix...
does anyone successfully configured it ?
Old 02-19-2011, 04:09 PM
Default Re: How to have Quick controls on Mc mix from cubase 6 ?
found it !! on the nuendo section of "eucon application setup" documentation.
: To use Quick Controls with MC Mix
Press and hold the EQ knob set selector until it blinks and then release.
Each of the selected track’s eight Quick Controls are displayed and can be adjusted with the encoders.
so good
I spend hours searching the web for an answer..
hope this post will be usefull for somebody not finding it in doc, as me..
Old 02-23-2011, 02:13 PM
ninjafreddan ninjafreddan is offline
Originally Posted by entoine View Post
so good
Excellent! Thanks for the tip, I had no idea it was possible to do.
That means that I can configure eight EQ parameters of my favorite EQ plug-ins and have easy access to them on my MC MIX.
Great news!
* UPDATE * Adding Quick Controls in Cubase 6 seems to add just one control on each Page. My MC MIX only shows one parameter at a time and I have to use the Page button to edit another Quick Control. But the I found out that I have to engage the CHAN button to show all eight parameters at the same time. I'm a happy camper now!
Any way to loose the knob acceleration and set a static value for increasing and decreasing the parameters? It would be nice if turning the knobs worked the same way as they do when using the EQ button, cause they don't seem to have the same acceleration or high sensitivity altering the built-in EQ in Cubase 6.
Cheers
Fred
Sound On Sound contributor
Ninja Production
PT HD 9.03 + HD Core card, Nuendo 5, Cubase 6, Wavelab 7, Samplitude 11, W7 64bit, ASUS P5B, Core 2 Quad 2.4GHz, 4Gb DDR RAM, UAD-2 QUAD (all plug-ins), RME RayDAT, Lavry DA-10, Mytek Stereo192 ADC, 2xApogee DA16X and Rosetta 800, Quested V3110 three-way speakers, Avantone MixCubes, Euphonix MC MIX, Novation Remote SL61 and Zero SL MkII, lots of funky outboard and analogue synths.
sci fi controls bonehead696 macOS 1 09-02-2013 09:37 PM
I need a quick reminder.(Bussing tracks to Aux for quick fade out) mexablcknesekid 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-16-2010 09:28 PM
Quick quick quick DSP farm card Question Mr335 Pro Tools TDM Systems (Mac) 1 12-06-2002 07:37 AM
MAC controls PC , PC controls MAC, wireless crazy stuff....you got to have it... lucian Tips & Tricks 7 12-13-2000 11:20 AM
Cubase with Digi001, where to set latency on Cubase Eiko 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-17-2000 08:28 AM
