Using Quicktime's GM Synth In Pro Tools
Hi
Is there a way to hear the default quicktime midi synth in Pro Tools? I know in logic you can set the GM midi tracks to trigger the QT synth but I can't figure out if its possible in PT. If it's not possible then maybe there's an instrument plugin that sounds similar?
2.8 Ghz (8-Core) Mac Pro 8 Gigs Ram PTLE 8.0 |
Re: Using Quicktime's GM Synth In Pro Tools
Your best bet is to use Xpand2. The Air Patchbay has a set of pseudo-GM presets that make it easier to use GM MIDI files
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R |
Ive just been struggling down this one - I use midi files for bits of tunes or a chord sequence and have struggled thru allocating expand and finding which track is which blah blah.....I wanted a method as easy as in OS9 when QTime would provide the GM sounds and I may have found one.
I found a free OSX synth called "simplesynth" to which I can allocate an IAC bus then I had to copy and ammend the PTools GeneralMidi.midinam file by adding "IAC Driver" as model and "AppleComputer,Inc." as manufacturer - now I can access the GM sounds on a programchange patch within protools and see the names again on each respective midi track and send all the midi to IAC and so onto simplesynth and hear the sounds. I am still on PT8 but using mboxpro I can hear the sounds and I guess when I get free enough to try PT9 then hearing and even recording the GM sounds should be even easier - though I rarely use the GM sounds once ive found what I need as I tend to allocate better sounds from the VIs instead |
multiple quicktime's in one session?? | Hamsterlott | Post - Surround - Video | 5 | 01-11-2010 05:09 PM |
Sonik Synth w/ Pro Tools | kravinski | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-26-2005 06:57 PM |
Lost Quicktime's Audio functionality | staplek | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-05-2005 07:43 AM |
synth pitch question for the all synth experts | riotbeats | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-13-2005 05:38 PM |
Soft synth vs Hard synth! Reason, Pro 52, V Statio | Jak | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 11-08-2003 10:51 AM |
