How can I run my Digi 001 5.0.1/Protools LE w/ XP?
I have an old Digi 001 version 5.0.1 & Pro Tools LE for Windows 98se. How can I run this with my new computer running XP?
Thank you in advance guys! |
Re: How can I run my Digi 001 5.0.1/Protools LE w/
I beleive you can download an update to 5.3.1 for XP for free. I'm not sure how the upgrade from 5.1 to 5.3 across OS versions works, though, so make sure you read all of the instructions and links carefully.
Honestly, I would recommend an upgrade to the last version available for the 001 for $35 at the DigiStore.
Re: How can I run my Digi 001 5.0.1/Protools LE w/ XP?
Yeah, Shawn is right. Get 6.4..that's a no-brainer.
happy tooling,
cheers, Andrew W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more 2.0 and 5.1 monitoring |
I will do that...thanx guys!
I have a dual core processor, have you guys heard of any issues with them and Pro Tools? My system: Pentium D 840 (3.20 GHz, 800FSB) 2 GB Dual Channel DDR2 SDRAM at 533MHz - 4 DIMMs 256 MB PCI Express TMx16 nVidia GeForce 6800 video card 500 GB Performance RAID (2 x 250 GB SATA HDDs) Hard Drives Windows XP Media Center 2005 Edition Sound Blaster9R) Live! 24-bit ADVANCED HDTM Audio |
Re: ..
I am using my 001 with PT 6.4 and XP. $35 is all it takes. you do need your 001 serial # though.
very stable and sounds great.
"Miracles do happen, snowmen fall from the sky completely unassembled" P4 2.0A-Intel 845GEBV2-1024 DDR-Radeon 7200 001-PT6.4LE-Nuendo-Reason |
Re: ..
Do I need to have any Pro Tools software on this computer before I download the new version? I do not have anything currently on this machine. I have not put the Digi 001 hardware in either.
Re: ..
No prior software necessary.
From the Digistore. Install the 001 hardware before installing 6.4. Also, make sure you apply cs6 and cs9 updates after 6.4 installation. |
Re: ..
After I install the 001 hardware and restart the computer, what should i do about the Wizard and it installing the old 98 drivers? And does the I/O box have to be hooked to the PCI card before i start the computer?
Re: ..
You ignore the New Hardware wizard as well as the Windows Logo warning.
You should read the installation overview and instructions in the Getting Started guide. All this is covered. If you don't have a copy, follow the Technical Documents link above. |
ProTools Ten and DIGI 002 | GTBannah | Pro Tools 10 | 4 | 06-21-2012 10:31 AM |
I NEED HELP! with protools LE and digi 001 | hoikki | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-21-2011 06:45 AM |
Protools LE 6.9 and DIGI 002<<<< |
twin.records | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-23-2005 10:29 AM |
PROTOOLS 24 TO DIGI 001 | Tell | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-06-2002 11:05 PM |
Digi: What we want from Protools! | Frost | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 11 | 03-24-2001 12:57 AM |
