Protools LE 6.9 and DIGI 002<<<<
Hy,
i`ve some problems - the configuration is DIGI 002 (not rack) with Apple G4 DUAL 1.24 GHz 1.700 MB Ram and 2 x 250 GB 7.500 U/min - and Protools LE 6.9. The Problem: The flipp botton no works correct but not the button the Programm is the problem. So when i open for example a session with about 30 channels - so the first 8 ones are blue and the 9 to 16 is yellow and when i like to change to 9-16 so it flips to 17-24. If i put with the right mouse button in ohne of the yellow channels it flips in the that at first of the 8 channels. Example i clic in the channel 10 (a yellow one - normal blue if its selectet) so it flips to channel 10 to 18. if i go back i am at the 1-8 channel and if i clic other wise the right button - it flips to 17-24. If some one knows something about this problem i welcome you to give me an idea whats wrong or ist it a bug in this version of Protools. Thanks alot and have a good time working on Protools. THANKS MAC (from Austria) |
Re: Protools LE 6.9 and DIGI 002<<<<
Nobody likes to help me?
Has this system always behaved this way or did this just start happening?
If it just started happening, try the 'General Troubleshooting' steps in the sticky at the top of this forum, specifically those on trashing preferences. Let us know if that clears up the problem. |
ProTools Ten and DIGI 002 | GTBannah | Pro Tools 10 | 4 | 06-21-2012 10:31 AM |
I NEED HELP! with protools LE and digi 001 | hoikki | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-21-2011 06:45 AM |
How can I run my Digi 001 5.0.1/Protools LE w/ XP? | lordestroyer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 14 | 01-10-2006 03:03 PM |
PROTOOLS 24 TO DIGI 001 | Tell | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-06-2002 11:05 PM |
Digi: What we want from Protools! | Frost | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 11 | 03-24-2001 12:57 AM |
