Old 03-28-2005, 07:47 PM
hitwriter hitwriter is offline
Default change gain, but volume indicator doesn\'t move.
In the mix window, when I change the gain on the 001 box for channel 1, I notice the led moves up, but the volume number doesn't change. Does the number showing beside volume indicator show where the level is near 0dbfs. Does it represent record level when a track is record enabled.
How do I change the tempo and not have it move markers? aasteveo Tips & Tricks 4 10-16-2019 01:20 PM
Converting Volume Automation to Clip Gain = Higher Volume! EricWillhelm Pro Tools 10 8 11-01-2011 11:12 AM
Tempo change causing midi volume to change plugin output tgrfox 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-05-2011 01:08 PM
change gain, but volume indicator doesn't move. hitwriter 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-28-2005 08:05 PM
volume/peak/delay indicator problem Zettt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 02-14-2004 09:24 AM
