Mixing Window, AutoMatch Indicator, can't change track volume....
I don't know how this indicator turned on, I've done research on it and looked it up in the Pro Tools Help menu, but nothing explains why the AutoMatch Indicator turns on or how to turn it off.
If anyone has some more information on this contact me ASAP because this has happened several times, where I have to restart a new session because a couple tracks will revert to the volume the AutoMatch Indicator was activated. |
Re: Mixing Window, AutoMatch Indicator, can't change track volume....
It's always "on." It's just an indicator for what you've done -- it doesn't do anything but tell you that things don't match.
It means you have volume automation on the track that differs from where your current fader is. Either delete the volume automation from the track or put the automation on the track from "read"/"auto read" to "off".
I had this exact same problem. For some odd reason, the volume fader on a particular track seemed to have a mind of it's own and get stuck on a certain volume level. When I would turn it up, it would pull itself back down and when it turned it down, it would pull itself back up. Even when I clicked "all" I was able to turn all tracks down but this one. I didn't do anything manually to change the volume level of this track so I had no idea why it started acting this way.
Ultimately, I clicked onto [audio volume] and then grabbed the audio line and moved it up and down randomly. Then I put it back to position "0". Strangely enough, that stopped it from wacking out on me and I haven't had anymore trouble with it. Perhaps that will work for you as well. |
Hrdw: Mac Studio, Lynx Aurora (n) 24 in 4 out, Sonnet enclosure with 2 UAD2 PCIe cards, Glyph NVMe SSD Drives |
Read post #2 and check what automation mode your track is in.
How come I can't change the volume in the mix window? | sb_stefan | Pro Tools 10 | 9 | 01-28-2020 05:19 PM |
Can't Mute or Change Volume on Audio Track and Instrument track | FunkTools | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 06-10-2010 04:40 AM |
change gain, but volume indicator doesn't move. | hitwriter | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 03-28-2005 08:05 PM |
change gain, but volume indicator doesn't move. | hitwriter | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 03-28-2005 07:47 PM |
I pan the MIDI track and get volume change- | Paul Cavins | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-30-2003 04:03 PM |
