Go Back   Avid Pro Audio Community > Pro Tools Software > Licensing & Accounts
Old 12-20-2023, 09:59 AM
Electronic1982 Electronic1982 is offline
Default Will my 1-year update code expire if I don't use it?
I have Pro Tools Perpertual,
I've just purchased a 1-year upgrade in the hope there will be good updates in 2024,
but I haven't used the Code yet
I would like to use my activation code when there is a valid update to Pro Tools,
will my code expire? or can I hold onto it for as long as I want?
Thanks.
Old 12-20-2023, 10:38 AM
The Weed's Avatar
The Weed The Weed is offline
Default Re: Will my 1-year update code expire if I don't use it?
IIRC, if purchased from Avid, the clock is ticking. If you bought it from an Avid Reseller, then the clock starts when you use it.
Hopefully someone from Avid will chime in.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 12-20-2023, 01:20 PM
JFreak's Avatar
JFreak JFreak is offline
Avid doesn't sell codes, Avid activates right away.
Janne
Old 12-20-2023, 02:09 PM
cvicente22's Avatar
cvicente22 cvicente22 is offline
Hi Electronic1982,
A redemption code purchased from a reseller that is unused doesn't expire, as long as the product is still being offered or not yet discontinued.
But if you buy directly from the Avid Online store, it automatically redeem the product into your account and that will start the entitlement date right away.
Regards,
Charles
________________
To create an Avid Support Case, you may go to https://www.avid.com/learn-and-support/contact-audio-and-music-support
Old 12-20-2023, 04:10 PM
Thanks all, it really helps, here's to 2024, cheers
Error with Pro Tools Ultimate 1-Year Updates + Support Plan Renewal code rimshot002 Licensing & Accounts 1 12-30-2021 05:23 AM
entering the code simply extends for 1 year AFTER my current expiration? MixerGuy Licensing & Accounts 2 12-03-2020 08:07 AM
FS: Pro Tools Ultimate + 1 year support and update plan XJENSEN Buy & Sell 1 08-23-2020 05:14 AM
Avid plugins expire after 1 year?? rexdigital Licensing & Accounts 5 09-16-2017 10:56 AM
Re: Your Waves Update Plan is About to Expire Touchwood Studios Pro Tools TDM Systems (Mac) 63 03-01-2017 01:01 PM
