Old 10-07-2022, 12:17 AM
M2E M2E is offline
Default Pro Tools 2022.9 hanging when quitting
Hello Everyone is anyone else having an issue when closing out Pro Tools and it pretty much gets to the end and then I have to Force Quit because it hangs on "Closing Session... Audio File Catalog". Other then that, it's been solid on an M1 Pro Mac.
Marc
New System: Macbook Pro M1 Max/16 gigs of Ram/Monterey/3 UAD Quad Satellites/2 PCIe Quad UAD cards/Waves Digigrid/Antelope Zen Pro/OWC 3 Slot Thunderbolt PCIe unit/Over 1400 plugins (Beta Tester for 15 different companies)
YouTube Channel https://www.youtube.com/watch?v=HaZYp2wNomc
Old 10-07-2022, 12:32 AM
Default Re: Pro Tools 2022.9 hanging when quitting
Quite possibly a corrupt session or a bad plugin. You need to troubleshoot.
Start at "help us help you" up the top of each DUC web page.
Old 10-21-2022, 02:50 PM
SFXgeek SFXgeek is offline
I'm having the same issue (hanging on quittting) since upgrading to 2022.9, iMac 2019 3.6 GHz Intel Core i3 running Mac OS 10.14.6
Old 10-21-2022, 02:59 PM
Where "bad plugin" == any plugin incompatible with your exact OS and you exact Pro Tools version... and you've changed that so...
Start by trashing prefs.
Moving all .aaxplugin files out of the plugin folder etc.
Doing all the other standard troubleshooting.
You have to go do this work, it's just pointless to ask what others might guess the problem is.
Old 07-20-2023, 04:07 AM
jackmackdaddy jackmackdaddy is offline
Hi there. Did anyone ever get any resolution to this? I'm having the same issue on PT 2023.6.0.110 and Ventura 13.3.1. It happens on every session including empty sessions. I have removed all .aax plugins from the plugin folder so it only launches with Avid's own AIR plugs but still needs an old force quit...
Old 07-20-2023, 09:00 AM
Pretty sure it is happening to many folks, I was too lazy to try too much detective work here, I just switched to closing sessions then exiting Pro Tools.
If you remove all plugin files on a Mac then Pro tools will automagically put back its *core* plugins. These are not what would be called the Air plugins…. air instruments and effects plugins are separate installers and not core plugins.
Old 07-20-2023, 01:11 PM
You're right, it's the core plugins that load automatically. I see on another thread that an admin has stepped in due to the number of users having the same issue and that a case has been logged (04647081) so fingers crossed there's some movement on it in the near future.
Old 07-21-2023, 11:01 AM
WombatStudio.Org's Avatar
WombatStudio.Org WombatStudio.Org is offline
Closing sessions first - enables Pro Tools to quit normally for you?
I always close sessions (Cmd+Shift+W) before quitting - it's 50/50 whether Pro Tools will hang on close for me.
I've been watching the threads, but I'll just Force Quit when necessary until they figure it out and release an update.
WombatStudio.Org • Digital Recording, Mixing and Mastering in Gibbsboro, NJ • USA
"It's not the gear ... it's the ear"
Old 08-03-2023, 06:54 PM
ghobish ghobish is offline
Just picking up on this thread.It's a new behavior for me since I got my Mac Studio M1. Running under Rosetta because some of my favorite plugs have not been updated for Silicon yet; seems more stable running native.
It always freezes for me whether quitting or closing.
I'm on 2023.3, on a perpetual license- and my 1 year of updates ran out a month ago! Does that mean I'm stuck with this behavior forever unless I subscribe when they have a fix?
Old 09-24-2023, 12:21 PM
Well, the new release is out and it doesn't solve the problem...
Pro Tools 2022.6 with Avid Control 2022.4 stargazer Pro Tools 2 07-01-2022 07:32 AM
Pro Tools Keeps Quitting macfreak86 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 01-12-2009 05:49 AM
Pro tools unexpected quitting ndawula 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 11-10-2004 04:22 AM
Pro Tools Quitting! seifaldin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-23-2004 03:15 AM
Pro Tools keeps quitting MLK 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-01-2004 06:06 PM
