Old 01-12-2011, 10:40 AM
BigEvil BigEvil is offline
Default SATA or Firewire 800 for higher track count?
I can't seem to find any solid documentation on this any more. I have a new Mac Pro that easily enables me to put in a dedicated SATA audio drive(probably a WD Black 7200RPM) however years ago I was having disk usage errors and track count limitations using SATA and was getting much better performance with FW800 drives. I'd taken the issue to the DUC and was informed by Digi Tech back then (this is likely 4 years ago) that SATA had lower track count limitations than FW 800 however I can't find any solid documentation on either side any longer. I just simply want to know if I'm better recording to my high performance digi approved FW800 drives or installing a dedicated SATA drive for recording.
In case this information helps its a Mac Pro 8 Core Westmere with 16GB RAM, dedicated separate internal system & sample drives. A typical session will be around 85 tracks with 2-4 plugins each however some sessions get up to around 125 tracks. Always 48k/24bit
Thanks so much for your help
Old 01-12-2011, 11:58 AM
Jon_Atkinson Jon_Atkinson is offline
Default Re: SATA or Firewire 800 for higher track count?
My understanding is that FW800 has a maximum sustained data transfer rate of 70MB per sec...
Most SATA II drives spec around 270MB per sec, but the protocol itself can sustain 3GB per sec...
SATA III is double that.
In the real world the difference is not so marked, but in my experience SATA internal drives wipe the floor with FW800.
Old 01-12-2011, 01:02 PM
Agreed, SATA should beat the tar out of FW800.
Old 01-12-2011, 01:17 PM
nst7 nst7 is offline
Even if for some reason you had issues, you could always put a second audio drive in there, and split the tracks between the 2 drives. But as the others said, it shouldn't be an issue.
Old 01-13-2011, 05:04 PM
O.G. Killa's Avatar
O.G. Killa O.G. Killa is offline
At 48KHz/24bit, you need 141KB/s per track. So look at drive specs and add up how much bandwidth you'll need. You also need to factor in the drive's seek time and cache. The larger the cache the faster it will be for music applications. Something with 64MB of cache should be able to hand a session with 125 tracks in it, regardless of whether it is FW800 or SATAII.
Which by the way, most FW800 external hard drives actually have SATAII hard drives in them and the internal FW chipset inside the case converts from SATA to FW.
Derek Jones
Sound Engineer / Producer / Composer
Derek Jones Linkedin
Megatrax Recording Studios
Megatrax Studios Yelp Page
A-list Music Artist Page
Old 01-16-2011, 11:44 PM
Guy McDude Guy McDude is offline
agreed.
Best,
Sean
Sean McDonald
Red Medicine Recording LLC
Sofa King Music Services
http://www.seanmcdonald.com
Old 01-16-2011, 11:55 PM
Kenmillerjr's Avatar
Kenmillerjr Kenmillerjr is offline
SATA hands down. Just installed two of them in my system this weekend, doing away with the need to track to a FW drive. Worked great with capturing 48 channels of audio yesterday!
Ken Miller, Jr.
Audio Engineer
Southside Baptist Church | Warner Robins, GA
| VENUE Profile 96X64 with MADI Option | ProTools 7.4.2 HD3 Accel PCI | ProTools 10 Native | MacBook Pro 17" OS 10.7.1 2.3GHz Intel Core i7 8GB Ram | Mbox 2 Pro | Mbox 3 Pro | Motu 896mk3 Hybrid |
Old 01-17-2011, 01:39 AM
JFreak's Avatar
JFreak JFreak is offline
SATA is the current king of the hill for reasonably priced hard drives. Internal or external, does not matter, but SATA is as fast as the drive itself can perform.
Opt for higher rpm drives if you can, it is the surest way for driving latency down. That is the #1 most important factor for getting more tracks. Cache will not help there if the drive itself cannot keep up. Cache is "only" good for reading stuff, not helpful for recording where a single hiccup stops the process.
There are 10krpm drives for sure, but if you need the very seriously best recording performance you have to get 15krpm drives. Sadly, I think these are still SCSI-only (?) but if someone can point out a 15krpm SATA drive, I'd be interested :)
Janne
Higher simultaneous recording track count in 7.3 coronos Pro Tools M-Powered (Win) 1 12-14-2008 12:09 PM
Trackball response slows down with higher track count QuickPuppy ICON & C|24 0 08-02-2007 01:34 PM
Internal SATA drive track count on G5/10.3.2 Samhein Pro Tools TDM Systems (Mac) 35 04-27-2004 08:29 PM
8meg drive buffer=higher track count?? Nitronick 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 04-17-2003 11:32 PM
Higher Track count for ProTools Le??? NuBus General Discussion 7 07-21-2001 11:48 AM
