Old 09-22-2008, 03:10 PM
soundguydave soundguydave is offline
Default File naming?
I have an question about how protools auto names regions as they are recorded. In our facility, we'll typically name the track we are recording too something like "vo_jeff_0922" So obviously its what type of recording it is, the VO name and the date. So all my regions look like
vo_jeff_0922_01
vo_jeff_0922_02
vo_jeff_0922_03 etc.
Now if jeff comes back for the same project a week later, I would like to name the file vo_jeff_0930 and have it start over at take/region number one, but instead it continues on with 4,5,6 etc. Now if I completely rename the entire track it will start over, but simply changing the date does not force it start over.
Is there someway to change this? or does it have to be a feature request?
Dave Kaduk
Particle Audio
Old 09-22-2008, 05:50 PM
degs7 degs7 is offline
Default Re: File naming?
great question.
I'd be curious to know as well.
Old 09-22-2008, 06:26 PM
Use a period...
vo_jeff_0922.01
when you create a new playlist it'll be named:
vo_jeff_0922.02
Regions are based on the track name and are appended with _nnn which constantly increases (as you've seen). To start the region numbers from 1 again, you'd have to create a new track.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 09-23-2008, 11:00 AM
Mario C Mario C is offline
You could leave out the underscore altogether.
vo_Jeff0922
PT will treat this date as part of the text instead of as a separate number, and changing the date will restart your numbering at 01.
Mario C
Metcom Studios
www.metcomstudios.com
Old 09-23-2008, 06:15 PM
Scott Goldberg Scott Goldberg is offline
I go Rail's way, put the period in. Things will increment in digits. Doing it right now with Documentary and it's really helping.
Scott Goldberg
Gold Recordings
http://www.goldrecordings.com
PT10 File naming weirdness IO Composer macOS 1 10-21-2011 09:22 PM
AUDIO FILE NAMING vjk Pro Tools M-Powered (Win) 2 07-13-2007 07:51 PM
Naming file crashing PT Farmer Dave Pro Tools TDM Systems (Mac) 8 12-03-2006 01:08 PM
file naming ofsaints Post - Surround - Video 2 11-28-2006 10:05 AM
Sequential File Naming dBgogogo Pro Tools TDM Systems (Mac) 1 11-29-2004 12:13 AM
