ups for power backup with PT
hi..
I`m going to install a UPS line interactive for my computer and computer monitors. The UPS only output square wave signal. I have heard bad things about connecting converters to line interactiv UPS. I have a tdm system with 888 interfaces So my question is. If the power fails and the 888 interfaces shuts down, Will I be able to backup the pro tools session? or do I have to run the 888 with a UPS as well? Do the 888 always have to be on to shut down the session? Any recommandations for a good power backup and spike protection for this setup? ?? thanks |
Re: ups for power backup with PT
The question of the UPS' output waveshape is generally over-thought. It might be square-wave, or filtered square wave but it's passing the juice straight out of your wall through to your gear when there's no loss of power (maybe filtered). So, only worry about what a square wave would do to the sound of your gear if you're planning on printing your mixes during the 10 minutes (or whatever) you have during a power outage.
On the other hand, most true "online" UPSes run with sinewave outputs. But might be overkill for your task. -dave |
Even if it doesn't break, it is a good idea to put them on your UPS. We get a lot of momentary power losses here, and having the 888/96/192s keeps the session running through those, without any "Lost connection" errors. |
Would this UPS (Uninterrupted Power Supply) protect and power my gear? | D_Japan | macOS | 4 | 07-24-2011 04:23 PM |
Power Conditioner and Battery Backup Question. | philip888 | General Discussion | 27 | 03-17-2010 04:28 PM |
Battery/Power Backup | 6figgas | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 01-08-2006 08:06 AM |
Backup Power Supply Question | chrispnyc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-18-2004 05:35 PM |
TRAVAN Tape Backup - compress audio backup or not ? | stoneinapond | Pro Tools TDM Systems (Mac) | 2 | 11-28-2001 12:35 AM |
