All regions have gone!!!
Hello everybody,
today something weird happened just after a BTD. BTD was OK, i saved the session and tried to close it but i got this message: Could not complete the Close Session command because Neo Assertion in /Volumes/Development/vb_cliff/AlturaPorts/SDKs/Neo61/Libraries/ Macintosh/Environments/Alone/../../../../Source/ CNeoStreamable.cpp". line 2247. I had to hard reset the computer because force quit did not close PT. I restarted the system, trashed databases etc and opened the sesion again. All the regions had dissapeared!!! Automation, plugins and midi data were there. Has anyone expirienced this madness and survived to the heart collapse??? Thanx for reading. P.D.: PT 7.3.1 HD5 ACCEL, 192 I/O(2)+AD192(2), MIDI I/O, ProControl + Fader Pack DIGIDESIGN 13 Slot Expansion Chassis APPLE PowerPC G4 MDD DUAL 1.25 GHz / 2G DDR SDRAM MAC OS X 10.4.8 GLYPH SCSI 36G (3)
PPC G4 [email protected] 2G RAM / Mac OS X 10.4.8 / PT 7.3.1cs8 / 2 x 192 i/o + 2 192AD Expansions / MIDI i/o / Digidesign 13 slot Expansion Chasis PCI13R / Core + Accel + Accel + Process + Process / ProControl+Fader Pack |
Re: All regions have gone!!!
did you try opening up one of the session backups?
AKA - EvilElfHobo Pro Tools 10 HD Native | Mbox 3 Pro | MacBook Pro 2.3 i5 | OSX 10.7.4 Pro Tools Music & Post Operator V6-8, Instructor, and Expert ICON Mixer Certified. Multi-Platinum Pro Tools Videos |
No session backups are available, i had this option disengaged.
sounds like you have a corrupt session, you can try starting a new session and importing session data from the old session to see if you can get all of your stuff back, but it's a long shot.
Trash all DigiBase folders... use the Digi utility... as mentioned in the sticky troubleshoting thread - this should be the first thing you do if you have a neo-error
Rail
Platinum Samples www.platinumsamples.com Engineered Drums for BFD •••••••••••••••••••••••••••• |
The funny thing is that all audio files are still inside the Audio files folder but they don´t show in the regions list.
I don´t use the session backup feature (which i should) because i backup the projects to another HD often (2-5 times daily). So i imported the regions and audio files from this HD and the session is OK now although something weird has arised: two tracks show spikes which never had been there before, they are like digital clips or glitches. I can get rid of them with the pencil tool, but what really makes me sick is that you never know when or how these things happen.
Sounds like you could have a hard drive problem starting. neo-errors are a sure sign that something can't be read or written from the drive or maybe ram. The spikes in the audio are what would happen when the files being read or written are interrupted, could be a power surge or similar, or something starting to fail. Chris
Thanx for all the answers.
Crizdee, do you mean i should change the RAM?
Key command to de-select regions previous and next regions? | jkuehlin | Pro Tools 10 | 1 | 08-03-2013 06:52 AM |
duplicating midi/inst regions auto-joins regions? | WestphalMusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 05-10-2009 09:44 PM |
realtime pitch (without time correction) in PT8? + putting audio regions into regions | fonografist | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 10-07-2008 11:15 AM |
"Select Unused Regions" selects USED regions. Please help.. | pukeuv | Pro Tools TDM Systems (Mac) | 9 | 04-26-2007 02:04 PM |
Regions madness! 6 edits creates 4200 regions!? | crizdee | Pro Tools TDM Systems (Mac) | 8 | 04-18-2005 10:21 AM |
