Can Someone Please remind what this means...?
Between all the updates and upgrades and all the other technical stuff that gets in the way of making music, I know I've seen this one before, but at this moment I just can't remember what this symptom indicates...
whenever I press a "bypass" button on a plug, or switch between input and playback, or any number of other "switches" in pro tools, I get a large and very nasty click. I know I've seen this one before, so if someone offhand happens to know exactly what it is, please inform me as I'm getting the sneaking suspicion that I may have a hardware issue here. I recently had some unwieldy issues with my rig that led me to finally rebuilding my startup drive from scratch (something I've never had to do before, what a complete time-suck) and what was even weirder was that when my regular startup drive got screwed up and wouldn't run PT without creating another user, my clone also got screwed up - bizarre. At this point, I'm losing confidence in my gear and really need to pin this down quickly and carry on with the work at hand. Could it be bad RAM? My RAM tests fine with Apple Hardware Test and memtest and Digitest says that my HD cards are good - of course we all know that these tests are largely inconclusive. HD2 Accel, Mac Dual 2G G5, 4GB RAM, Rosetta 800 / X-HD Much Thanks for any help! |
Re: Can Someone Please remind what this means...?
Whenever I've had severe popping from switching plugs, assigning outputs, etc, a restart of the computer fixed it.
I hope this isn't more serious than a restart for you. PT7.4.1 HD2, G5 Dual 2.3PPC, 4GBRam |
Its usually caused by one specific plugin, more often than not its an effect plugin and usually RTAS. have you got TL Space, Echoboy, Altiverb or similar on an fx bus? Try muting all your channels and unmute one at a time etc till you find the culprit. Can also be caused by clocking issues with digital ourboard routed in to pro tools mixer. Chris
Re you running delay compensation? I notice it a lot more when so.
Anybody know what this means? | Mordoth66 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 07-09-2008 01:48 PM |
Duh ... remind me about templates | jonah day | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 09-06-2007 02:57 PM |
Shortcut -- can someone remind me? | WildHoney | Pro Tools TDM Systems (Mac) | 6 | 12-16-2006 08:37 AM |
Does this mean what I Think it means? | waxnsteel | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 09-18-2004 08:07 PM |
Please tell me what this prompt really means.... | Roy Howell | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 11-26-2001 11:21 AM |
