embadded audio in omf
I can't really find a way to export OMF from ProTools 7.4 LE, with DV toolkit 2, and to embed the audio into OMFI. In the manual it is mentioned at some point, but there is not a particular explanation. Anybody could help me with this?
Re: embadded audio in omf
It's in the dropdown windown next to audio format:
fore as far a i know its the same in TDM and LE but correct me if i'm wrong.
Please excuse my English i'm a dyslectic |
Yes, it is there, so also with LE+DV toolkit2
thank you Nedd |
yup,
select all the tracks you want to export AND the length in the timeline. then select export |
You asked about embedding the audio in the OMFI:
Note, you cannot embed audio into an OMF from PT. PT will only create a linked OMF with a folder of linked audio files. Unless I've missed something since last time I did this? |
You can make both external and embedded OMF and AAF with PT. frank.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
Thanx to all for your reactions, it is possible to export embaded audio, as Danny Prent said, it is a dropdown window next to audio format. It just looked odd since that is the same window where you would choose format of your exported audio files.
I thougt after that it comes option (under audio media options) of exporting it all in one embedded file. But no, Digi sees it as a kind of audio format?!? We should think like that, no? |
I like learning new stuff |
Importing audio files for remix - convert or set session to match source audio? | LSW | Tips & Tricks | 22 | 09-09-2014 09:28 PM |
Audio Suite process puts new audio in audio bin | Fritz12534 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-21-2009 08:55 AM |
PRO TOOLS giving 2 Audio track ''Audio 5_02.L and Audio 5_02.R'' | fredson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 12-20-2008 09:08 AM |
How can I bounce mutliple audio/instrument tracks as mono Audio files in ProTools LE | thaprof | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 09-16-2008 11:03 AM |
USB2 Audio HD vs Fw Audio HD vs internal audio HD | seth666 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 07-07-2005 02:06 AM |
