Old 01-19-2013, 04:46 AM
mirovaz mirovaz is offline
Default USB Keyboard not responding
I have a UMX25.
Since I installed the lastest update for PT10.3.3 it stopped working.
I can go to the Utilities->AudioMidi Setup and the UMX25 is there. I can test it and pressing a key emits sound. But in PT there is no way I'm getting sound to the Virtual Instruments.
Any help?
Old 01-19-2013, 05:02 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: USB Keyboard not responding
Originally Posted by mirovaz View Post
I have a UMX25.
Any help?
Try this
Go to MacHD/user/Library>Preferences> and trash 'com.apple.midi.a bunch of numbers and letters.plist'.
And also trash 'com.apple.audio.audiomidisetup.plist'.
Empty the trash and restart, then see if everything is working.
Chris
Producer, Engineer,
www.ukmastering.com
Old 01-19-2013, 12:12 PM
colinmansfield colinmansfield is offline
Originally Posted by crizdee View Post
Try this
Chris
That's great advice and should work well. I had a similar problem with a couple of M-Audio Oxygen 8 keyboards, where PT couldn't see them (I replaced the first with a second). Audio MIDI Setup saw them, PT didn't... But in between testing with AMS and PT, I had moved the units slightly... turns out I had a bad USB cable that wanted to slip out of the keyboard(s). replacing that made things better...
Colin Mansfield
Bandcamp
Soundcloud
Old 01-21-2013, 03:25 AM
grovephil grovephil is offline
It may be that the VI is muted, this is independent to the channel mute. Show the instrument at the top of the channel strip, check midi ins & mute status.
I would assume though that you would have tried several different instruments and aren't getting a midi signal into PT.
Old 01-21-2013, 06:36 AM
Keybeeetsss's Avatar
Keybeeetsss Keybeeetsss is offline
Do u have a power source on the Midi keyboard or ur just powering it via usb? (If the other things don't work, u probably need to get an AC adapter if u don't have 1)
Sent from Da GS3 On'eim...
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
'' (that dopey green thing)
('we' must start using pronouns)
Virtual instruments not responding to keyboard JGlen Windows 2 02-21-2013 11:25 AM
RTAS Capslock Keyboard? Midi Keys triggered from computer keyboard. aasteveo Pro Tools 9 0 11-06-2011 06:17 AM
Not responding to midi keyboard ggrill macOS 2 01-20-2011 01:48 PM
003 Not Responding drummer1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-02-2008 05:18 PM
882 not responding, HELP!! JeffT Pro Tools TDM Systems (Mac) 1 05-30-2005 05:48 PM
