Reduce latency when monitoring audio inputs
Hi , whats the best option for reducing latency on audio ins.
I have an extrernal midi keyboard playing an arranged midi part in my PT10 arrangment. I have the audio from the keyboard monitoring on an audio track but obviously there is latency. I would like the monitor the keyboard through audio whilst working for a while and record at later stage after adding some midi tweaks / CC infomation etc. I have tried to switch on the low latency option but that seems to stop the audio being monitored. Waht else can i try so i can keep it monioring live without too much latency before I record it. Help appreciated
Protools 10: Asus M2N 1392 : 8GB Crucail DDR2 800 : MBOX PRO2 |
Re: Reduce latency when monitoring audio inputs
Can you lower your HW buffer size to 128 or lower?
C
PT 2021.10 HDX 16x24 -Mac Pro 12 Cores 48 GB RAM OS 10.13.6 - API 16 channel - AMS Neve 16 channel, AMS-Neve-SSL -Pres/Processing, Bock Audio, BLUE Bottle, Neumann, Josephson -Mics, Bogner, Kemper- Guitar, Chandler Zener-Curve Bender Outboard/Master. UAudio, Waves, Plugin Alliance etc. |
i can try that but i think it will freak the computer out / get stops whilst playing.
isn't the low latency otpion suppossed to fix this issue?
Does not the Mbox 2 Pro have hardware monitoring? I get the good results with a Focusrite Trakmaster Pro by receiving the session main outs into the Pre and then can mix that with the direct in from the keyboard. This works with the actual keyboard audio, but not with a software instrument that is running inside of your session. The MIDI from the keyboard is recorded simultaneously onto a track that will be used for playback of the VI.
The sound you hear while recording is whatever your keyboard is set to output. Once your MIDI track is recorded, you can copy that, or load a virtual instrument. The timing should be accurate. |
New DIGI003....problems monitoring inputs while playing back audio... | paulseling | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-04-2008 09:22 PM |
No audio during low latency monitoring?? | connelldestructo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 03-27-2007 04:27 PM |
Mac Pro - Latency when Monitoring Inputs | Davidm | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-23-2007 03:13 PM |
Monitoring Audio Inputs | Rick Millar | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-03-2006 11:14 AM |
Any way to reduce latency with Direct I/O driver? | steinn | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 11-03-2004 07:29 AM |
