Old 06-29-2011, 08:51 AM
Bodie Bodie is offline
Default Worthless error "unable to initialize the..."
Had this one this morning, booted as normal, running PTHD9 and at the final initialization of the audio hardware, received something to the note of "unable to initialize the chosen audio hardware...yada, yada"...
Thought this was related to my dual boot installation I did last night, so I did a complete reinstall on the core partition, same issue...noticed that the splash screen was PT9, not PTHD9...
Then it occurred, I'd pulled the iLok key from the usb to test another usb key device...replacing the iLok key solved the problem. It had NOTHING to do with the audio device, but had everything to do with an iLok authentication.
IMHO, a worthless error message...as it didn't point to the culprit at all.
Bodie
i7 950, 12Gb, 3 Tb, Win7-64 and 32bit
PTHD 12.7 HDCore 1 & w/002r
Macbook Pro 4Gb, 500G, OSX 10.6.2
iMac 3.06ghz, 16Gb, 2Tb, OSX 10.6.2
Minimoog Voyager, Liberation, Taurus, Phatty
Korgs, Nords and more
Arp 2600s & Ody
Old 06-29-2011, 10:01 AM
Dism Dism is offline
Default Re: Worthless error "unable to initialize the..."
Actually... It's quite correct, since you can't use your TDM hardware without a PTHD license.
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
"Unable to locate the settings folder" plugin error question GoodandEvil Pro Tools 11 1 12-30-2013 04:55 PM
"unable to parse audio file" and "OSStatus Error -208" ! reichman Post - Surround - Video 2 03-22-2010 04:46 AM
After update to 8.0.1 error "Pro Tools is unable to reacquire the hardware" NailZ Pro Tools M-Powered (Win) 1 10-28-2009 01:25 PM
"Can't Initialize DirectIO" Error AMIII, Win 2K rpoulos Digidesign Hardware & Software 1 01-22-2003 07:06 PM
"unable to allocate disk space for recording" error guslov 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-01-2002 08:15 AM
