Old 02-23-2011, 08:36 PM
tdubthatsme tdubthatsme is offline
Default I like the tones that are on my synth, but how do I record them?
I have basically set up a recording using old gear my school had and was not using. The main issue I am running into is that I have no VI. However, I have a casio wk3700 synthesizer that has tones on it. How can I record when I play those tones? I currently am running through a firewire 410 to a macbook and using protools 7 academic version.
I tried directly plugging the 2 1/4" keyboard outputs into the 410's inputs in the back, but it didn't work.
I am basically teaching myself how to do this, and have run into this problem. Thanks for any help in advance. And sorry if what I said made no sense...
Old 02-24-2011, 07:59 AM
Default Re: I like the tones that are on my synth, but how do I record them?
Just create a stereo audio track and select the inputs your Casio is plugged into and record it I take it your Pro Tools 7 is M-Powered? To avoid confusion, I would refer to it as PTMP 7. Pro Tools LE 7 would not work with the 410 at all. Also, look at the front of the 410 and see if you need to push a button to get the DI inputs to work(something like a "Mic/DI" button).
Old 02-24-2011, 11:33 AM
I think I missed the button on the front. I will try it, thanks!
Can you record the audio/tones of plugins so you can reduce the amount you are using? JohnnyCrash 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 01-20-2010 10:57 PM
Using Midi Keyboard to Record Subtractor Synth sh336697 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 01-07-2005 02:44 PM
how do you record a soft synth? sonoma bass 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 10-03-2002 12:51 AM
How would you record drumkits out of synth? DougSt.Louis 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 10-01-2002 06:17 PM
What method do you use to record drumkits from a synth into PT? DougSt.Louis Pro Tools TDM Systems (Mac) 2 10-01-2002 03:47 PM
