Is there a way to change track view via PC or Edit pack
When mixing and editing, i switch between Waveform and volume view VERY often....is there a way to do this via the PC or Edit pack ??? Thanks
Re: Is there a way to change track view via PC or Edit pack
well, not quite the answer you're looking for,
but, i have a pc, and like you, switch between those two views constantly. i do it with my kensington; just programmed one of the buttons to go back and forth. indispensable. b.o.l. e
ihatetyping |
elicious,
I also have a Kensington Expert Mouse. I tried to program button 3 and 4 to do exactly that but it does not seem to work. Wich mouse do u use ??? Thanks |
yo v,
yes, the same expert mouse. i have the bottom 2 buttons combo'd together to do it- open keystrokes menu hit Control-dash together and name it; should be good to go. toggle again goes back to waveform. b.o.l. e e.p.s. and don't forget, it'll work on grps or temp grps by hitting shift-option.
ihatetyping |
Is there a way to automatically bring a track you select into view in the edit window | Focuret | Artist Series | 4 | 01-05-2013 01:48 PM |
Track view in edit/mix windows | Ben Jenssen | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-26-2009 05:06 PM |
Quick key for changing edit view to volume view in track? | postman56 | Pro Tools TDM Systems (Mac) | 4 | 11-30-2007 10:56 AM |
Why change "Scroll track into view" in 7.2? | Syn-g | Pro Tools TDM Systems (Mac) | 19 | 08-29-2006 01:39 AM |
Change view sizes quickly in Edit Window | Mason00 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 12-03-2005 10:56 AM |
