Old 05-28-2007, 03:02 PM
Touchwood Studios Touchwood Studios is offline
Default Card Slot Order MacPro Dual 3.0 Quad
I have a Quad core Mac Pro with HD 3 Accel PCIe and Protools will not start up with more than the Core installed.
It appears that the card slot order is wrong. There is nothing in the installion guide of slot order for Mac Pro's
Protools Boots OK with just the core care but protools fails to start with any Accels cards installed.
The TDM cables are installed OK Port B on Core to Port A on the next Accel card etc.
Any hints would be great. Thanks
Old 05-28-2007, 06:20 PM
Dutchmuzik Dutchmuzik is offline
Default Re: Card Slot Order MacPro Dual 3.0 Quad
Probably bad flexcable, have you tried starting with cards seated but not connected ?
Old 05-28-2007, 07:09 PM
lumpo lumpo is offline
AFAIK, the core goes in slot 2 (whatever's nearest to the video card), the accel cards in 3 and 4. However, it may be a compatibility issue. I just ordered what I thought was a 2x2 3Gig MAc Pro and mistakenly I got a 2x4 (silly me!) This system reports hardware errors when my PCIe host card for my digi expansion chassis is put in. I've had to revert to a G5 whilst Digi (hopefully) produces a compatible PCIe host card for the 8-core machines.
Old 05-28-2007, 10:35 PM
Acoring to the Compability page the 3.0 Ghz Dual Processor Dual Core is qualified.
All the cards are seated OK.
Old 05-28-2007, 11:16 PM
soundproof soundproof is offline
I've just ordered a new Mac Pro and a HD2 system - Has the card order really changed from the G5 times? It used to be the other way around with Core on the furthest slot from the video card.
Old 05-28-2007, 11:49 PM
the dude's Avatar
the dude the dude is offline
just had the same exact problem and it turned out to a bad accel card out of the box brand spanking new . just put in one card at a time to find out which one was bad
even the digitest application would crash till the card was removed
http://www.studio-techservices.com
าำ
[email protected]m
Mitch Berger Tech Services
We service ALL Avid products no Problem
HD192, 192, Omni, Control Surface, Pre, XMON, 192HD AD & DA / Accel Cards, Everything
ALL NEW HD192 AD -DA modification. the difference is incredible... no need to ship the entire unit , fast turn around
inquiry using link above
Repairs of SSL-Neve- Consoles and Repair ALL Modern & Vintage Gear
Old 05-29-2007, 05:54 AM
My bad - of course the Core goes there right after the video card...
Old 05-29-2007, 06:18 AM
DAPG DAPG is offline
I had the exact problem too. It was a bad Accel card.
Roy Machado
Dallas Audio Post
PCI Slot Card Order emf1138 Pro Tools TDM Systems (Mac) 0 09-02-2004 09:22 PM
Card slot order niki111 Pro Tools TDM Systems (Mac) 4 04-05-2003 05:43 PM
4 slot Magma correct card order James Thomson Pro Tools TDM Systems (Mac) 1 09-24-2002 06:11 AM
Magma 6 slot mix card order? cinecity Pro Tools TDM Systems (Mac) 2 09-15-2000 06:13 AM
Card Slot Order for PTMix Plus on 9500/150 NY909 Pro Tools TDM Systems (Mac) 0 12-24-1999 08:09 AM
