Old 01-25-2006, 04:31 PM
K.B. K.B. is offline
Default One midi keyboard to trigger two sounds or more?
I've a Korg keyboard with midi in/out going into my 001 at the moment. Is there a way of getting the midi to trigger two instruments or plugs on seperate tracks? Or, more specifically here, two instances of the same plug on different tracks but doing slightly diferent things (one up front, and the other with some reverb providing the ambience)?
When I try doing it the korg trigggers one midi track or the other, but not both at the same time.
Just trying things out...
Old 01-25-2006, 09:08 PM
Default Re: One midi keyboard to trigger two sounds or more?
K.B.
Karel, I just created four Instrument tracks, two I inserted with Reason and two with
Moog Modular V. Enabled Instrument View and routed each channel accordingly.
Instrument Track One Reason NN-19 channel 6 Rewire Mix L / Mix R
Instrument Track Two Reason Subtractor channel 4 Rewire channel 3 and channel 4
Instrument Track Three Moog Modular V 2 1 channel 1
Instrument Tack Four Moog Modular V 2 2 channel 1
Shift clicked record arm, Alt clicked faders
All four Instrument tracks playing different sounds with one Key stroke ...for example.
Is this what you had in mind?
filosofem
Aaron Mulqueen - 001 HD Native
Old 01-26-2006, 01:00 AM
Sounds like it.
But you have PT7 which now has instrument tracks, whilst I've still got 6.4 on my 001 with the old midi tracks. It seems like (unless I've missed a setting somewhere) 6.4 will only route a midi input to one midi channel at a time.
I must be missing something. Maybe I should RTFM.
Anyway, I got my discounted MBox ready to unpack, and I now have a full PT7, so maybe I should install that...
Old 01-26-2006, 02:53 AM
Palli-Moon Palli-Moon is offline
I'm a 6.4 user as well, and well I can't have pro tools in front of me while I say this so this maybe a bloody lie. But still, can't you just create 2 midi tracks and an aux put your instrument on the aux and record arm both midi tracks holding shift and clicking on the rec on both of them?
Old 01-26-2006, 03:14 AM
shift + click...
Of course. I'll power the machine up and try that right now!
(p.s. who else is busy doing their tax return at the last minute right now? )
Old 01-26-2006, 04:16 AM
Got it working. Thanks. Knew it had to be something obvious!
Old 01-26-2006, 06:36 AM
hehe guessed it was the shift key you forgot. No problem, good to be of any help
P.S. If you read the post above again, that you thought was all about the instrument channels, you can see he also adviced you to use shift :P
Old 01-26-2006, 05:30 PM
K.B.
Good to hear you got your setup working, Karel. Yeah I forgot 6.4 doesn't have Instrument tracks, but would've mentioned what Palli-Moon suggested, after realizing it or been told that 6.4 does not support that option. Maybe I should've paid more attention to begin with.
You and me both!
...just out of interest, can you have both systems running side by side, on the same DAW?
filosofem
Old 01-26-2006, 06:44 PM
K.B.
Don't bother Karel, I found the answer.
filosofem
Old 01-27-2006, 01:16 AM
Alesis DM6USB drums recognized but won't trigger/play MIDI sounds yeenar Pro Tools Express on Windows 0 02-25-2014 04:32 PM
MIDI keyboard doesn't trigger sounds on time staylow Pro Tools M-Powered (Win) 3 11-30-2010 06:17 PM
Built in sounds in midi keyboard mike1234 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 04-10-2009 04:57 PM
Recording drums sounds using MIDI keyboard. songwriter1 MIDI 0 02-07-2009 01:31 PM
OT - OSXApp to playback sounds with a midi trigger Syncman Pro Tools TDM Systems (Mac) 1 11-01-2005 03:39 PM
