Old 07-10-2008, 04:34 AM
Willbloke Willbloke is offline
Default SPDIF mic pre/comp/lim ?
Hi there ,I've got an Mbox pro , is there any ( preferably budget ) Mic preamp/limiter/compressor that's got SPDIF so I can utilise the digital input ?
Cheers,
Willbloke
Old 07-10-2008, 05:56 AM
tpthai2 tpthai2 is offline
Default Re: SPDIF mic pre/comp/lim ?
The Aphex 230 Voice Channel would be a good one to look at.
Old 07-10-2008, 06:10 PM
Presonus Eureka
Old 07-11-2008, 03:54 AM
Hmm , thanks for that , but no budget options ?
Old 07-11-2008, 04:24 AM
Phil Ogden Phil Ogden is offline
http://www.samsontech.com/products/p...1651&brandID=2
http://www.myspace.com/philogg
Old 07-11-2008, 04:42 AM
Thanks Phil , that's more my budget
Anyone used one ?
Old 07-11-2008, 05:37 AM
BradLyons BradLyons is offline
Well, what kind of quality are you expecting and what is your budget exactly? What mic are you using? What will you be recording with it? What other gear do you have to use in conjunction? These must be addressed before a recommendation can even be made or considered.
Thank you,
Brad Lyons
www.howavl.com
Old 07-11-2008, 08:05 AM
"Well, what kind of quality are you expecting and what is your budget exactly?"
Best possible , cheapest possible !
"What mic are you using?"
Not got one yet , looking at a Sontronics STC2 .
"What will you be recording with it?"
Voice and instruments .
"What other gear do you have to use in conjunction?"
Nothing at present !
Right , I'll explain ...
I work in a University supporting Mac Pros with PT LE. ( Focusrite , Lexicon outboard)
I've was into music tech years ago, but never took it any further than "arseing about" , I guess you'd say .
Since we started this course last year , my enthusiasm has returned and I'm building a "studio" in my spare bedroom.
I don't need ( can't afford) professional results .( I can always pop into work if needed )
I looked at the Samson , all cool other than it only does 48 and 96KHz , I was aiming for 44K !
I've been recommended dBX 360 http://www.dbxpro.com/386/386.php , but money's tight !
As I'm an Electronics Engineer , I'm looking to build myself some outboard ( comp/lim etc)
This isn't a commercial facility , doesn't need best in the world gear , it's just a hobby , so ideally I need to minimise my outlay .
I think that about covers it !
Oh , my setup at home is PC , MBox 2 Pro , Alice mixer , prodipe monitors , errr , that's about it at the moment !
Cheers for the replies !
Old 08-17-2008, 07:02 AM
Default
If anyones interested , I popped for one of these http://www.edirol.net/products/en/M-10DX/
I've only given it a brief test and seems to work fine.
( I've actually got it running over 20 metres on SPDIF , which is against the rules , but seems stable )
I know it's not pro quality , but it does the job!
*edit ... just noticed , I've put this in the Mac section when I've got a PC at home , Doh !
Old 08-17-2008, 08:34 AM
twig twig is offline
Default
Originally Posted by albee1952 View Post
Presonus Eureka
ive been looking for the same input pre...spdif. i have a eureka and my model does not have this option...i beleive the new ones do so just ask before purchasing. i love mine for what it is....(a low end channel strip/di). cheers
ProFire 2626: SPDIF COAX & SPDIF OPTICAL Simultaneous success!!! WHAAAA HAPPENED??? cueball73 macOS 0 05-22-2012 12:41 PM
mono like sound from spdif out (GA-EX58-UD3R) to spdif in (Omni ) chrisdee Pro Tools HDX & HD Native Systems (Mac) 9 04-02-2012 05:10 AM
Digi 96io - can you mix Optical SPDIF and phono SPDIF? buckaroo Pro Tools TDM Systems (Mac) 1 08-24-2009 11:20 AM
PSP Master comp, nearest plugin comp to Manley Vari MU? crizdee Pro Tools TDM Systems (Mac) 1 05-22-2007 05:21 PM
pros and cons of comp-eq or eq-comp dw Tips & Tricks 4 01-28-2001 03:10 PM
