Computer hangs at PT startup since upgrade to 7.0
I upgraded from 6.9 to 7.0 a few weeks ago and have had problems starting PTLE since then. It takes two or three reboots and attempts at startup before PTLE will load completely. The problem occurs while the splash screen is showing. It starts and immediately jumps to "Loading DAE setup" (something to that effect)and hangs. The computer won't even let me stop the program with the task manager or restart Windows when that happens. I have to hit the reset button to restart.
My system is an ASUS A7V600 motherboard with an Athlon XP2500+ CPU and 1GB of Crucial RAM running XP Pro with SP2. Before the upgrade this never happened. I have installed the latest PT CS updates hoping that the fix for whatever is causing this would be included. I have searched the Answerbase without luck. I am hoping that someone else has had this problem and found a fix for it. I am at work right now so I don't have the Sandra data handy but I can post it tomorrow when I get off if necessary. Any ideas guys?
--joe |
Re: Computer hangs at PT startup since upgrade to
I've got the same problem. 7.0 on an Mbox2. The first time I launch PTLE after a reboot - I get a hang on DAE error -1115 as PTLE is starting up. It closes itself down, and the 2nd time it always opens. I had 6.8 running (well, not totally running, see below) - and never had that error. Since I upgraded to 7.0 I get this DAE error. Tried to uninstall 7.0 and do a clean reinstall - which decided to crash my Windows XP system files, so I had another mess on my hands simply getting my computer to boot up again. Finally fixed that, got a clean 7.0 install - but still have this DAE problem. Tried deleting DAE preference files as states in the "General Troubleshooting Thread" - but still no luck.
I'm running a Dell 4700 (yes, with the 915 chipset). 2.8 ghz HT, gig of RAM, dedicated Firewire drive for PTLE - but I recognize the chipset further complicates things. When I had 6.8 had other errors - but not this DAE thing. I've been pouring over the tropics trying to find workarounds with my machine - and just got a powered USB hub, but still working on getting the system to work. Anyone? -Matt |
Re: Computer hangs at PT startup since upgrade to 7.0
We had the same problem, reformatted and reinstalled 7.0 clean. Takes 3 seconds to load now. For what ever reason XP does not like the upgrade.
Anyone else having this problem?
--joe |
I have the same problem, need a solution.....when we say "reformat do we mean remove PT or reinstall the OS??
Have you verified that all installed plug-ins are Pro Tools 7 compatible? If not, start there - if you are unsure about the compatibility of a particular plug-in, remove it until it's compatibility can be determined.
More information on plug-in compatibility can be found here: http://www.digidesign.com/download/70/ |
the only third party plug i have is izotope. the others are the ones that came with PT LE7 with the addition of the dynamics III plugin. if i read the document correctly, izotope is cool with le7. any other ideas?
thanks -aaron |
New PT 10 upgrade won't complete startup: hangs on "Restoring Windows" | georgelegeriii | Pro Tools TDM Systems (Mac) | 0 | 11-19-2012 12:14 PM |
PT LE8 Windows hangs on startup | richdog | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 08-12-2010 03:48 AM |
HELP! PT Hangs Up On StartUp. | Steve@ZooWest | Pro Tools TDM Systems (Mac) | 5 | 05-22-2010 12:15 AM |
PT8 hangs on startup looking for Waveshell | Luuu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-22-2010 12:07 PM |
5.0.1/G3 B&W Hangs @ StartUp!! | DFatz1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 14 | 07-17-2000 01:07 AM |
