rewire problem
I have been trying to solve my protools rewire with sibelius to no avail! all suggested trashing of preferences, re installs done. No luck! is anyone having this problem? 2 top Avid products. help me out here!
mac os 11.3.1 protools 2020 sibelius 2021 ableton 11
protools 2021 12.0 sibelius 2021 os x 11.3.1 big sur minimac intel i7 (16 GB 2667 MHz DDR4) |
Re: rewire problem
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (2) TC Electronic Studio Konnekt 48 Avid Artist Mix/Control Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
Re: rewire problem
http://www.sibeliustutorials.com/usi...ls-via-rewire/ Seeing you're on Big Sur, are you using a device with Apple Silicon? This could definitely be a deal breaker. Rewire is deprecated so when it breaks, sayonara.
Re: rewire problem
Thanks James, my mini mac is i7 intel.
I have followed all protocols - trashing pref files, reinstalling sibelius and protools. It's a mystery. much appreciated.
Re: rewire problem
What IS the problem you're having??
Re: rewire problem
thanks Chris, indeed, not a very complete description of my problem-
I don't get sibelius to show up as instrument in protools or ableton. previously, when protools was running i could use sib as rewire instrument (aux track, instrument) where everything functioned perfectly. After an update of sibelius (ultimate 2021 at this point) it no longer worked. I followed all protocol- trashing pref files, then with no luck, reinstalling sib and protools. any help would be much appreciated! cheers!
Re: rewire problem
Maybe this article will help.
Re: rewire problem
in other words, rewire is not working. Sib doesn't appear in protools or ableton as 'instrument' or 'track'
Re: rewire problem
thanks! but- i have read this article- and done all of the trashing of files. still doesn't work.
rewire problem
There was an old school requirement that a rewire instrument had to run stand-alone the very first time to write the rewire value. After that, it would then show up. Did you run Sibelius in standalone mode once before trying to open it as a rewire instrument?
Rewire problem | sleepingtiger | Pro Tools 12 | 3 | 02-16-2017 08:01 AM |
Rewire problem | BeatleNut | Pro Tools 10 | 0 | 07-02-2014 09:51 PM |
Rewire Problem | irishharry | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-13-2010 01:48 PM |
PROBLEM with ReWire and PT LE | MEM-NYC | Tips & Tricks | 3 | 01-08-2004 10:21 AM |
rewire problem | akushner | Pro Tools TDM Systems (Win) | 3 | 11-20-2003 12:16 AM |
