Old 08-02-2004, 08:52 AM
samrisio samrisio is offline
Default help with mic volume too low in mix
how can i get my mic volume up? it is way too low..i am going thru a mixer with an audio technica atm41a and then thru the m box...thanks in advance
Old 08-02-2004, 08:59 AM
Chris Cavell Chris Cavell is offline
Default Re: help with mic volume too low in mix
Here are a few options if the problem is in the mix:
pan, eq, compress, turn it up, turn everything else down a bit, ride the fader, etc...
If your signal is too low at the converter, turn up the mic pre.
Cavell Studios
Old 08-02-2004, 09:23 AM
Default the problem is when recording not the mix
it is very dim..do i need another pre amp? there is ome in the behringer ub1832fx and the m box has one but i cant hear the mic very loud
Old 08-02-2004, 09:29 AM
Captain_Pants Captain_Pants is offline
Default Re: the problem is when recording not the mix
Turn up the Mic volume.
Im not trying to make you sound like an idiot, because this happened to me, but my damn mic would barely make any noise...couldnt figure it out...then i Figured it out, the thing needed a new battery. I dont know what kind of mic you have, but try that out if applicable.
Ill suffer winter alone;
ten thousand miles from home...
Old 08-02-2004, 09:32 AM
scottedog scottedog is offline
samrisio,
I think Chris nailed it...
Have you tried that, where do you have it set? I'm not familier with that mic, does it need phantom power? If it does is it switched on?
Scott.
ScottedogStudios on ReverbNation
Old 08-02-2004, 10:43 AM
Default how do you turn up the pre amp?
i have everything going thru a mixer into the m box and am using line in..should i be going into the mbox direct with the mic? i dont need phantom power for the ATM 41a
Old 08-02-2004, 10:45 AM
Default Re: how do you turn up the pre amp?
Ahh.. If you dont need phantom power than you should definately check the battery(if there is one), and probably shouldnt be going Line in, that could be why the signal is so low.
Old 08-02-2004, 10:59 AM
there is no battery and it is a brand new mic...there are pre amps on the mixer but you are saying go direct into the m box and it will make a difference...does line in exempt the m box pre amps? and if i went into the outlet on the back of the mbox am i going to get stereo out?
Old 08-02-2004, 01:43 PM
where02190 where02190 is offline
What brand/modle mic? does it require phantom power? What happens when you plug it directly into the M-box mic pres?Have you checked all your cabling?
Old 08-02-2004, 01:47 PM
Forget the mixer for now, plug the mic into the source 1 input in the back of the Mbox & turn the gain knob UP.
You might also want to have a read thru this.
Scott.
Monitoring volume in Pro Tools doesn't match computer volume Drakken Pro Tools M-Powered (Win) 0 01-17-2012 02:56 PM
Converting Volume Automation to Clip Gain = Higher Volume! EricWillhelm Pro Tools 10 8 11-01-2011 11:12 AM
Track fader volume to send volume smmdrum Tips & Tricks 9 08-12-2008 05:22 PM
MP3 Bounce Volume too low, Normalization & Reference Volume Daniel P 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-15-2007 12:11 PM
Special paste midi volume to audio volume? Richard Fairbanks Pro Tools TDM Systems (Mac) 0 07-30-2003 09:52 AM
