Old 01-25-2010, 02:14 PM
Stixxs Stixxs is offline
Default Stuck loading LE8?
Hi all,
Trying to load LE8 on a pre-owned MacPro...i need a password to allow installer to do it's thing, emailed the original owner. Any other options?
Thanks much!
Old 01-25-2010, 02:50 PM
Default Re: Stuck loading LE8?
Got it...thanks just the same.
Old 01-25-2010, 08:46 PM
smpkeys smpkeys is offline
If you bought a used mac, you should start with a fresh OS X Install.
Everything you need to about setting up your mac for Pro Tools can be found here:
http://duc.digidesign.com/showthread.php?t=54888
Good luck!
2010 Mac Pro, 3.46 GHz 6 Core Xeon,32 GB RAM, OSX 10.9.5, PT 12.4, RME Fireface UFX, Command 8, Mytek 8x192, SSD evo on System,Audio&Samples on spinner drives WD SATA 64mb Cache
Stuck on "Pro Tools Loading" Hookstarz Pro Tools M-Powered (Win) 2 03-08-2010 10:44 AM
Opening Help! ProTools 8.03-Get's stuck loading AutoTune 5 WorshiperDj 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 01-23-2010 05:24 PM
When loading PT 7.4.2 gets stuck on 'DigiRewire'...please help!! larsizzle 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 09-29-2008 04:09 PM
002 STUCK IN VALIDATING AND LOADING SCREEN (BANGAH) 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 07-23-2003 10:50 AM
Protools 5.1 LE freezes when loading (DAE is stuck?) blazer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-28-2002 12:03 AM
