Old 03-27-2018, 08:35 PM
manubsingh manubsingh is offline
Default S/PDIF input on 11R?
Hello,
I'm trying to figure out how to use and listen to the s/pdif input on the 11 Rack. I currently have the S/PDIF output from my Fractal AX8 connected to the S/PDIF input of the 11R, but it's completely silent. Is it possible to use this connect like an input from another amp modeler like the AX8?
I am looking through the manual and the forum posts, but I can't seem to figure this one out. Please help if you can
Update: I found out it's the rig input section. Thanks! (Please delete this if you can/want to)
Old 03-27-2018, 11:24 PM
Stig Eliassen's Avatar
Default Re: S/PDIF input on 11R?
You found the solution so we'll leave the thread up. It could help others.
Thanks.
s/pdif input on 001 RasBeats General Discussion 2 03-21-2004 01:26 PM
S/PDIF - Can not input to 001 MilesD 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-21-2003 11:51 AM
S/PDIF input on PT 6 ? groove guru 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-28-2003 11:21 PM
888 interface's s/pdif input doesn't like AMIII s/pdif output jmark 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 10-19-2001 01:03 PM
s/pdif input too low?! remer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-26-2001 02:33 PM
