Old 06-22-2021, 03:41 AM
ronnievanoverveld ronnievanoverveld is offline
Default Re: Multi channel sync issue
OK, thanks Jfreak for your time and explanation! I'll try to it in PT then, as it's an audio sync issue.
Ronnie van Overveld - Sounddesigner - The Netherlands
Mac Pro Trashcan OSX Mojave, ProTools 2021.3.1 Ultimate, Focusrite Red4pre, Avid S3, Avid PT DOCK, AJA IO XT
Old 06-22-2021, 03:42 AM
JFreak's Avatar
JFreak JFreak is offline
No problem. Once you know how many samples you need to move, use the same amoung on every file and there will not be any phasing.
Janne
Old 06-23-2021, 02:33 AM
LDS LDS is offline
Some of the less expensive wireless audio transmitters and receivers have some pretty gnarly latency to them. Sennheiser AVX for example is 19ms. There are some cameras that also mess with timecode accuracy a little too, like some Reds.
If the timecode is correct on the video, have you tried just syncing it with the original audio rushes/dailes in MC, rather than the camera sound? I would have thought that would have been a lot easier than trying to readjust the camera sound.
Pro Tools Ultimate 2024.3. OSX 13.6.5. Win 10. HD Native. Lynx AES16e. Lynx Aurora 16. i9-13900KF. ASRock Z690 Steel Legend. 64GB Ram. AMD Vega 64. BM Decklink. Dolby Atmos Renderer 5.2. Trinnov D-Mon. D-Command.
Old 06-24-2021, 12:22 AM
Yeah, the digital latency is annoying indeed. The Tentacle Track E should not suffer from it, as it it runs on TC.
The problem is the amount of footage which is out of sync. I think it eventually will be fixed by audio post (which is unfortunately not done by me).
Old 06-24-2021, 06:30 PM
Vedat's Avatar
Vedat Vedat is offline
Quiet Art Ltd.
Originally Posted by ronnievanoverveld View Post
For a Dutch TV series, the video department has recorded audio on camera and with the new Tentacle Track E. Strange thing is that audio on camera is 1,5 frame out of sync (Later). So; track 1 (Tentacle), right timing, track 2 and 3 camera audio (1,5 late).
We now want to do media management in Avid MC, but want to first get rid of the delay. Is there a program (Soundminer?) which can take care of this problem in batch (lots of data!)? It's important to keep the timecode meta data in the files, but cut the 1,5 frame delay.
I hope I described it understandable ;-).
Thanks in advance for your suggestions.
Ronnie
Sound Devices Wave Agent app allows you to tweak the start TC of files but you can't "offset" them in batch I don't think.
Also, you can't do half frames in this scenario. They'll need to be all manually synced or use something like Plural Eyes.
Vedat
WaveRider + Defaulter (now with LKFS)
QuietArt.co.nz
Catchin' SYNC app
  #16
Old 06-24-2021, 10:15 PM
Luc Bernard Luc Bernard is offline
Check AbsentiaDX.com
Or soundradix.com/products/auto-align-post/
Those are the best tools I know to Align location audio. The AbsentiaDX is a Pro-Tools plugin, but also a stand alone application that can batch process folder's of .wav footage, and align phase. And those new .wav are ready for Media Composer import. And it retain all the original metadata from the source location broadcast wav files.
You need to select "a guide track", like the Boom on track 1. It will align all the other tracks in phase with the guide. It can work awesome for a few frames offsync.
À+
  #17
Old 06-30-2021, 07:10 AM
Thanks Vedat en Luc for your replies, sorry for my late reply!
AbsentiaDX seems like a good option there then, I'll look into that!
HTML code is On
Multi-channel vs Multi-mono plugs on 5.1 tracks geitz Post - Surround - Video 0 06-08-2007 09:06 AM
Multi-channel vs Multi-mono plugs on 5.1 tracks geitz Pro Tools TDM Systems (Mac) 0 06-07-2007 02:54 PM
multi-channel vs. multi-mono plug-in pinstudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-02-2005 11:59 AM
I Need Clarification. Difference between Multi Channel and Multi Mono Plugs citi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 06-13-2002 11:08 AM
Multi Mono vs Multi Channel Plugins...Just curious... Mr T 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 03-18-2002 09:46 PM
