Old 02-25-2012, 09:07 AM
elovaarar elovaarar is offline
Unhappy I Delete ILOK key Pro Tools HD9 and bundle licenses
I Delete ILOK key Pro Tools HD9 and bundle licenses.
How do they get back?
Can someone help!
Thanks
Roy
Old 02-25-2012, 07:50 PM
Unhappy ILOK key Pro Tools HD9 licenses back?
Can someone help!
Thanks
Roy
Old 02-26-2012, 03:57 AM
fireberd fireberd is offline
Default Re: ILOK key Pro Tools HD9 licenses back?
You will likely have to reinstall PT. When I first installed PT MP9 on my PC, I skipped the iLok install as I already had iLok installed for Antares and POD Farm. However, I couldn't start PT as the iLok support for PT was missing. I did a reinstall, including the iLok software and then PT started without problems.
PT MP9/Sonar X1
Ozone 5
Member of Nashville R.O.P.E. Assn.
Old 02-26-2012, 05:51 AM
It is tested for re-installation. Does not help.
Since I am already registered once PT9HD can not register again.
And that's why I can not get licenses ILOK appear!
I'll post a query AVID SUPPORT.
However, thanks :)
Old 02-27-2012, 03:56 AM
Have you checked your account on the iLok site? May be a problem that the iLok site can correct?
PT MP9/Sonar X1
Ozone 5
Old 02-27-2012, 05:36 AM
I've looked, and there has not been downloaded from a license.
Roy
Old 02-27-2012, 09:39 PM
Smile Re: ILOK key Pro Tools HD9 licenses back?
AVID support send liceses back.
Old 02-27-2012, 09:40 PM
Smile Re: I Delete ILOK key Pro Tools HD9 and bundle licenses
Old 02-27-2012, 09:53 PM
DigiTechSupt's Avatar
Post Re: I Delete ILOK key Pro Tools HD9 and bundle licenses
Hello Roy,
CS will need more info, so you should contact Avid CS to resolve this issue.
Avid Audio Tech Support
Support FAQ
Old 03-01-2012, 07:34 PM
Thumbs up Re: ILOK key Pro Tools HD9 licenses back?
This case is OK
AVID COMMENTS:
I can see that your HD 9 bundle has been accidentally deleted. Normally we charge a license replacement fee in these cases, but I've replaced your bundle free of charge as a courtesy in this instance. This can be downloaded
Best regards,
Toby
Avid Audio CSA
How to transfer iLok licenses from old to new iLok mschaeffer General Discussion 3 08-16-2013 05:55 PM
Lost iLok need help getting Licenses back. Corpop-13 Pro Tools 10 35 03-08-2012 01:57 PM
[HELP] Pro Tools not recognizing licenses on Ilok dsdaniels Windows 3 10-27-2011 01:27 PM
Can You Transfer iLok Licenses To A New iLok If Your Old iLok Is Broken? epu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 09-07-2009 03:51 AM
DIGI HOW DO I GET MY ILOK LICENSES BACK???? catfish11 Pro Tools TDM Systems (Mac) 6 08-10-2006 06:52 PM
