Best version of PT for Digi 003 on W7?
I bought a Digi 003 and can't get it working, and haven't gotten any help here. I have clients waiting on me to mix their projects and I need to get the Digi working. I have PT LE 7.4, PT LE 8.0-8.4cs2, and PT 9.01. Which version will I have the most success running the Digi until they fix the PT9+Digi 003 issues? Thanks!
SiSoftware Sandra Computer Model : Gigabyte 965P-DS3 Workgroup : JLHOMENETWORK Host Name : JLMAIN-001 User : Jaime Landers Processor Model : Intel(R) Core(TM)2 CPU 6600 @ 2.40GHz Speed : 2.4GHz Cores per Processor : 2 Unit(s) Threads per Core : 1 Unit(s) Type : Dual-Core Integrated Data Cache : 2x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size L2 On-board Cache : 4MB, ECC, Synchronous, ATC, 16-way, 64 byte line size, 2 threads sharing Computer Mainboard : Gigabyte 965P-DS3 BIOS : Award (Phoenix) F10 01/12/2007 Bus(es) : X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 3.5GB DIMM DDR2 Chipset Model : Giga-Byte P965/G965 Memory Controller Hub Front Side Bus Speed : 4x 267MHz (1GHz) Total Memory : 6GB DIMM DDR2 Channels : 2 Memory Bus Speed : 2x 401MHz (802MHz) Memory Module(s) Memory Module : Corsair CM2X2048-6400C5 2GB DIMM DDR2 PC2-6400U DDR2-800 (5-5-5-18 3-22-6-3) Memory Module : Corsair CM2X2048-6400C5 2GB DIMM DDR2 PC2-6400U DDR2-800 (5-5-5-18 3-22-6-3) Memory Module : Corsair CM2X1024-6400 1GB DIMM DDR2 PC2-6400U DDR2-800 (5-5-5-18 3-22-6-3) Memory Module : Corsair CM2X1024-6400 1GB DIMM DDR2 PC2-6400U DDR2-800 (5-5-5-18 3-22-6-3) Video System Video Adapter : NVIDIA GeForce 7600 GS (12 PS3.0, 5 VS3.0 401MHz, 512MB DDR3 540MHz 128-bit, PCIe 1.00 x16) Graphics Processor Storage Devices KINGSTON SNVP325S2128GB (128GB, SATA300, 2.5", SSD) : 119GB (H:) WDC WD3200AAKS-00SBA0 (320GB, SATA300, 3.5", 7200rpm, 16MB Cache) : 298GB (C:) (E:) WDC WD1501FASS-00U0B0 (1.5TB, SATA300, 3.5", 7200rpm) : 1TB (I:) SONY DVD RW DRU-830A (ATA66, DVD+-RW, CD-RW, 2MB Cache) : N/A (D:) Logical Storage Devices Windows 7 (H:) : 119GB (NTFS) @ KINGSTON SNVP325S2128GB (128GB, SATA300, 2.5", SSD) Media (E:) : 170GB (NTFS) @ WDC WD3200AAKS-00SBA0 (320GB, SATA300, 3.5", 7200rpm, 16MB Cache) Storage (I:) : 1TB (NTFS) @ WDC WD1501FASS-00U0B0 (1.5TB, SATA300, 3.5", 7200rpm) Windows XP (C:) : 128GB (NTFS) @ WDC WD3200AAKS-00SBA0 (320GB, SATA300, 3.5", 7200rpm, 16MB Cache) 3.5" 1.44MB (A:) : N/A Optical Drive (D:) : N/A @ SONY DVD RW DRU-830A (ATA66, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : Giga-Byte 82801HB/HR (ICH8/R) LPC Interface Controller LPC Legacy Controller 1 : ITE IT8718F Audio Device : Giga-Byte 82801H (ICH8) HD Audio Controller Serial Port(s) : 1 Parallel Port(s) : 1 Disk Controller : Giga-Byte 82801H (ICH8) 4 port SATA Controller Disk Controller : Giga-Byte 82801H (ICH8) 2 port SATA Controller Disk Controller : Giga-Byte JMB36X PCIE-to-SATAII/IDE RAID Controller USB Controller 1 : Giga-Byte 82801H (ICH8) USB UHCI #4 USB Controller 2 : Giga-Byte 82801H (ICH8) USB UHCI #5 USB Controller 3 : Giga-Byte 82801H (ICH8) USB2 EHCI #2 USB Controller 4 : Giga-Byte 82801H (ICH8) USB UHCI #1 USB Controller 5 : Giga-Byte 82801H (ICH8) USB UHCI #2 USB Controller 6 : Giga-Byte 82801H (ICH8) USB UHCI #3 USB Controller 7 : Giga-Byte 82801H (ICH8) USB2 EHCI #1 FireWire/1394 Controller 1 : Lucent/Agere Systems (Was: AT&T MicroElectronics) FW322/323 IEEE1394 OHCI FireWire Controller SMBus/i2c Controller 1 : Intel ICH SMBus Printers and Faxes Printer : Send To Microsoft OneNote 2010 Driver (1200x1200, Colour) Printer : Microsoft XPS Document Writer (600x600, Colour) Printer : hp psc 1300 series (1200x1200, USB, Colour) Printer : HP Deskjet 3050 J610 series (300x300, USB, Colour) Fax : Microsoft Shared Fax Driver (200x200) Printer : Adobe PDF Converter (4000x4000, Colour) Scanners and Cameras Scanner : Hewlett-Packard HP Deskjet 3050 J610 series (USB) (Scanner, 1200x1200, USB) Network Services Network Adapter : Marvell Yukon 88E8056 PCI-E Gigabit Ethernet Controller (Ethernet, 1Gbps) Network Adapter : ADMtek AN983 based ethernet adapter Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows 7 Ultimate 6.01.7600 Platform Compliance : x86 Windows Experience Index Current System : 4.1 |
Re: Best version of PT for Digi 003 on W7?
9 is the only officially qualified version for win 7.
8.0.4 was the first version to officially support Windows 7 for PT LE and M-Powered.
http://duc.avid.com/showthread.php?t=277427
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
If you go with the XP drive, then I would run 8.0.1cs2
I second that... On XP/32, 8.0.1 cs2.
On my Avid account I don't have access to 8.0.1 cs2, only 8.0.0 and 8.0.3. Do I need to download an update for 8.0.0? Thanks everyone, can't wait til they fix this and I can use the Digi on PT9!
Having PT8 should allow you to get any or all updates, all the way thru 8.0.4cs2(different cs2 than the one for 8.0.1). Personally, I am quite happy with PT9 on Win7 64 bit. The faders sometimes don't bank correctly, but I don't need them that much(but your work flow may differ from mine)
Digi 001 Le Version 6.4 on xp | The Billy Ray Band | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 12-13-2007 04:23 PM |
Digi 001 with Version 6.4 | rchaffin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 07-28-2004 06:07 PM |
New Digi MME Helper Version 1.2 | Rail Jon Rogut | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 32 | 02-21-2004 08:59 PM |
Another version of PT with Digi 001 | jeronimo | General Discussion | 1 | 01-13-2001 12:01 AM |
when is PC version of digi 001 due out? | tross | General Discussion | 6 | 03-07-2000 07:59 AM |
