Recording drums
I've been using superior drummer inside pro tools to do a demo for my bands music. The other guys in the band want to record live drums in a living room. With an 8 channel console how can I route this into pro tools, I've never touched this subject before (I've only used virtual instruments)...
Re: Recording drums
What exactly do you want to know? How to setup the console's inputs in PT, or how to split up the drums into 8 channels?
iMac Pro - MacOS 10.14.6 --- - Pro Tools U HDN 2019.6 - Avid HD Omni + HD I/O 8x8x8 - C|24 | S3 | Dock |
Re: Recording drums
What interface do you have? With an Mbox, recording a full drumkit is going to be iffy at best(a great sounding kit, in a great sounding room with 2 great microphones......maybe). My favorite method is to use a Roland electronic drum kit with real cymbals(2 mics would work okay here) and let SD2 provide all the "shell" drum sounds. Pre-mixing 8 mics into 2 channels(to feed an Mbox) requires you to get the kit really good BEFORE it hits the Mbox.
Re: Recording drums
I'm working with only a Mbox mini so I'm really limited I'm sure. I just wanted to figure out all my options. Probably wishful thinking, but is there a way to go direct out from a mixer and go into the line in on the Mbox? This is basically what I'm trying to achieve.
Re: Recording drums
Yeah, with the Mini, all you can do is create a stereo mix with any outboard mixer, and feed that into the line inputs(quarter inch) of the Mini(and probably record to a single stereo track). To get good results here, the kit needs to be in great tune and condition(because you can't fix much after the recording). I would hope that the drums are in a room that is separated from your recording area, and you may need to use headphones to dial in the kit mix(put the mixer by the Mbox and use a snake going to the drum kit).
Re: Recording drums
To be honest...some of the best recordings I've ever done of a drumkit has been on two channels only. I've had to run the mics through a 8 channel desk, then out as stereo into say a stereo tape recorder.
This forced me to make decisions at the time of recording and not leave myself with too many options at a later date. It forces you to be more critical with your mic selection and placement at the time of tracking which is where its most important. I did use the onboard eq carve out spaces for each drum to sit nicely, and I had to be mindful of how I was intending on recording the bass later. As in, is the bas going to sit below or above the kick? What is going to drive this tune? I sometimes used some compression on the snare and kick on the way in just to get them to be a little more present than the rest. From there you take the time to get the mix right. Lets be honest...this is what live engineers do everyday, and I'm sure everyone has heard an awesome concerts in their day. Also, I generally use a bit of multiband compression once the stereo track is on PT to emphasise different things. Also, some interfaces have 2 x stereo channels. This may give you the opportunity to get some cable splits to turn 2 stereo channels into 4 mono channels. You can do the same thing with a mixer as well. Good luck...and remember...there is no substitue to real drums in a real room.
- Macbook Pro 2.5Ghz, 4gb RAM, 320Gb HD @ 7200RPM - 2 x Profire 2626 - PT8.0.1 M-powered - Yamaha HS80M - Axiom Pro 49 - 500GB Sarotech Hardbox external HDD plugged through express card, FW800 - Waves Gold bundle, L3-16, Eddie Kramer - 2 x Coles 4038, Royer 121, 2 x Shinybox MXL, 4 x SM57, 3 x SM58, AKG D112, SM81, Shure 16A, sE 2000, 3 x Audix D2 |
Re: Recording drums
Have to agree with barters81, except to remind you that SD2 actually IS real drums in a real room. They just got recorded by somebody else in another room
Re: Recording drums
On a different note......did a session on the weekend with a new band, and I got the most awesome snare sound. Supposedly some million dollar awesome snare drum. Just goes to show how much good instruments effect what were doing as well.
Re: Recording drums
Amen to that. A great instrument is always a good choice(too bad we don't always get that choice)
Re: Recording drums
BTW, Yes you can go line out of a mixer into the Mbox. |
Recording drums from a mpc! | Rallen | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 06-02-2009 07:21 AM |
Need Help Recording Drums | spex8929 | MIDI | 0 | 01-03-2009 07:19 AM |
Recording Drums | josephk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 04-05-2003 12:02 AM |
RECORDING DRUMS | REDDAWG083 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 03-09-2002 12:31 AM |
Recording Drums | bassmac | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 01-26-2001 01:42 PM |
