Old 05-24-2005, 12:16 AM
sco sco is offline
Default Is 6.9 stable?
I am currently using 6.4 TDM in a PC and it is VERY stable. I am having a Digidesign tech dood upping me to 6.9 on Friday this week. Does anyone have any problems with 6.9 TDM that they would like to share?
Old 05-24-2005, 04:23 AM
Rammelt Rammelt is offline
Default Re: Is 6.9 stable?
As long as you don't use MIDI and RTAS instruments, you should have nothing to worry about.
If you do, and need it to work flawlessly, I would wait if I were you.
Best Regards,
John
John Rammelt
Producer / Composer / Post
Hajp AB
old site:
Soundfactory JPR
Old 05-26-2005, 08:03 AM
audiomastermind audiomastermind is offline
hello,
i'm running 6.9 with hd 3 on a pc
it looks more stable to me than 6.7
hardware setup is easier, and some other things too
for instance, with 6.7 i had something going on with a stereo
master fader, when i put a stereo track in input-mode, i had
only the right channel going out the master
as soon as i changed the level of the masterfader, let say
from 0.0db to -1.0db, the left channel came back
rgds
philip
www.littlemajorproductions.be
www.audiomastermind.com
Old 05-26-2005, 12:30 PM
Rock_Artist Rock_Artist is offline
More stable than 6.7 ALOT!
New great features however it use more ram there is a major memory leak since 6.7 and 6.9 didn't fix that.
More RAM = Better
Just wanna do music,
RA.
Old 05-26-2005, 04:20 PM
Brandonx1 Brandonx1 is offline
Hi Rock Artist,
Man, I'm getting the memory leak also. Please email me off line so we can discuss this. How much ram are you using?
Peace,
Brandon
Brandon Howlett
Vibe Audio Post, Inc.
Re-recording Mixer
Custom Build CPU, HDX 1, Omni, 192 I/O Digital
S6 M10 24 fader
Satellite Mac Pro, HDNative, 192 I/0
Black Magic HD Extreme
Old 05-29-2005, 05:19 PM
I just confirmed it's a PT software issue. I didn't change anything else but the version of PT. 6.4 uses 300 MB of ram. 6.7 and 6.9 use 500 at first play and 2 MB of ram every addition play. WTF man. This really need to be fixed. By the way, I only see the memory leak on bigger session with lots of automation. DIGI, what's going on?
Peace,
Brandon
Brandon Howlett
Re-recording Mixer
S6 M10 24 fader
Old 07-27-2005, 07:40 PM
PTLance PTLance is offline
Big bump on this. This issue needs to be addressed immediatly!! It really should not have been released until this was figured out!! Any news Digi!!!!??!!
Old 07-27-2005, 09:35 PM
Digi ETS Digi ETS is offline
Yes, there is news.
We have a reproduced this in-house and are working on a fix. We plan to have an update out to you as soon as possible...meaning in a couple of weeks, not months.
thanks.
Digi ETS
Old 07-27-2005, 10:04 PM
Yeah!!!!!!!! Please fix the leak.
One thing, I was told buy digi that if I minimize pt and max it again, the memory resets itself. This is not the case with the paging file. You can see it in the task manager. PF stays the same when you minimize pt 6.9. Ass soon as you use an audio suite process, the memory maxes and no paging file is left. This makes PT just about unusable. So digi, please test this also.
Peace and thank you,
Brandon
Brandon Howlett
Re-recording Mixer
S6 M10 24 fader
Old 07-28-2005, 02:11 AM
It's not just one leak there are some leaks in the code.
I've also can confirm now after upgrading our rig that it's not only memory that counts.
We have no 2GB of RAM and still after some period of working especially with those big sessions when you chop everything with BeatD. the system gets sluggish ...
So RAM would make it function better but not make the sluggishness stop.
RA.
Is PT9.0.6 stable under W7 64? GrievousAngel Windows 16 02-10-2012 09:04 PM
Is 7.2 Stable Enough Yet? EarHole Post - Surround - Video 5 12-01-2006 01:38 PM
The Most Stable Mac OS? session48 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 14 10-30-2006 05:59 PM
is 7.1 or 7.2 more stable on HD3 G5? MixerGuy Pro Tools TDM Systems (Mac) 0 10-25-2006 11:03 AM
PT 7.2 / which OS is the most stable ? Aquarius Pro Tools TDM Systems (Mac) 7 07-31-2006 09:50 AM
