Old 04-06-2004, 10:14 PM
bruno_auclair bruno_auclair is offline
Default 442 interface
I just got an old 442 interface... I know it's an old interface used by avid systems or PTII, I also know that it connect to an Amadeus or PTIII disk i/o. What i'd like to know is witch card will be the best for me, I am currently running on a 9600/300 with SCII card and performer 6.3, and would like to use the 442 with a PT software! Amadeus cards go for about $150 and PTIII Disk i/o for about $300, would I be better of with a 001 and PT LE? Would Digi001 work with the SCII card?
Old 04-07-2004, 01:41 AM
Default Re: 442 interface
I believe you'll need a Nubus Mac for the 442.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 04-07-2004, 10:41 AM
I know for sure that I can connect The 442 interface to a Amadeus (PCI) card, my question should have been, could I use this set up (442 interface with amadeus card) to run PT software and if so witch version (LE, PTII, PTIII, PT24)????
Old 04-07-2004, 03:21 PM
jeffro's Avatar
jeffro jeffro is offline
Pro Tools software (up through 3.x) only supported the 442 Interface on a NuBus Audio Card (SA4).
Amadeus was a modified Disk I/O-PCI card (no SCSI) made specifically for Avid. It was never supported by Digidesign software.
Here are some abase articles that might help as well...
http://answerbase.digidesign.com/detail.cfm?DID=1077
http://answerbase.digidesign.com/detail.cfm?DID=54
http://answerbase.digidesign.com/detail.cfm?DID=53
• linkedin •
Old 04-07-2004, 07:10 PM
In one of the spec sheet you linked in your previous messge it says :It can also be used with an Audio Card (SA4) in a PTIII system to provide 4 additional inputs/outputs. (Requires a TDM single piggyback. Doesn't add DSP or voices.) Could I use a PTIII (PCI) disk i/o card to hook the 442 or is it only with the SA4 and a nubus PTIII disk i/o? I am only trying to find a use for that 442 interface! Maybe with a project card and digital performer!
Old 04-07-2004, 08:03 PM
jeffro's Avatar
A 442 Interface and card could be added to a Pro Tools III system to get 4 more inputs/outputs. It would look something like this:
1) Disk I/O <-> 882 or 888 (8ch) Audio Interface
2) DSP Farm
3) Audio Card (SA4) <-> 442 (4ch) Audio Interface
All cards would need TDM Piggybacks and be linked with a TDM Cable.
• linkedin •
HTML code is On
Alessis Multimix8usbfx interface and Mbox 2 interface with Protools 11 Majorpain7 Pro Tools 11 0 01-06-2014 07:40 PM
1 interface, 1 hard drive, only ONE firewire interface? beyoutofull1 Pro Tools M-Powered (Win) 5 11-22-2010 04:08 PM
Jeff Han's "no-interface" interface - soon for ProTools ??? ith_e General Discussion 5 04-13-2007 07:59 AM
is there a digital only i/o interface compatable with digi interface connections? Felix Tips & Tricks 2 10-22-2001 10:50 PM
SDII/Digital Interface/Analog Interface Question Karmitz Digidesign Hardware & Software 1 07-15-2000 12:30 AM
