Old 03-23-2004, 11:07 AM
yvesfeder yvesfeder is offline
Default dead channels in edit window PT 4.2 NuBus TDM/888
Hi there,
I've noticed doing edit mixes of say 14 channels (7 stereo L/R pairs) on occasion, even though the waveforms will show up, one or two channels will be "dead" - that is, no output (no matter what I/O's are selected).
I can move the "dead" channel say up or down the order of channels, and then the output is fine!
And the funny thing is, it's NOT always the same channel (in the sequence from top to bottom, i.e. 1 to 14 say) that appears dead. Right now in one particular edit session there are two "dead" channels - both of them left channels in two stereo pairs.
This occurs with all outputs assigned to 1-2/888 which I've always done when mixing to stereo out prior to bouncing.
If it were a hardware problem, wouldn't I see the same dead channels all the time?
I have two DSP farm cards and they are not maxxed out with plug-ins, all those work just fine.
Any ideas at all?:)
Thanks!
Yves
Old 03-23-2004, 03:02 PM
jeffro's Avatar
jeffro jeffro is offline
Default Re: dead channels in edit window PT 4.2 NuBus TDM/
Couldn't find anything in the Answerbase or older call logs like this, so it's tough to say where to start...
Is there anything unique about the tracks that do this?
Does this happen with just the "core" digi plug-ins?
Does the hardware check out okay in DigiTest?
Have you tried running with 1 DSP Farm at a time?
linkedin
Old 03-28-2004, 08:14 PM
Turns out it was merely conflicting voice assignments.
Stupido Me!
Y.
Old 03-29-2004, 11:39 AM
jeffro's Avatar
Glad to hear that you solved it, thanks for following up to let us know!
linkedin
HTML code is On
Mix Window Freezes but Edit Window works fine. wwicklund 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-10-2022 10:57 AM
Is there a key command to zoom in vertically on the channels is the edit window? BillytheB Pro Tools 11 6 03-17-2014 03:22 AM
Can I hide tracks in Edit window but not in Mix window? Avi Bortnick 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 06-07-2010 06:31 AM
888 with 2 Dead Channels Table Syrup Records Digidesign Hardware & Software 3 11-18-2009 07:10 AM
Cannot change EDIT MODE in edit window Xavior Pro Tools M-Powered (Mac) 2 05-24-2007 12:51 AM
