Mbox 2 pro - multi client?
I have a Mbox original and am thinking of upgrading to an Mbox 2 Pro, but wondered if the new versions are multi client?
I use Logic, PT and Ableton on a Mac G5, but with the current Mbox, you cant use for example, PT open and seperatly Logic open, I also do this (without rewiring) with Pt open AND Abelton Live, with a 828mkII, but when I try and use the mbox it says "digi driver in use" Do the newer mbox2 family allow you to have any programs open? so i could use this as a standard soundcard for Logic/Ableton? Also I see that the mbox2pro has numerous inputs/outputs, can i connect an outboard compressor with (2 outputs and 2 inputs back in) and use it as an external effect? Thirdly, does the Pro version come with the DV toolkit? |
Re: Mbox 2 pro - multi client?
AFAIK, PT needs exclusive use of CoreAudio so it will not be available to other audio applications whilst PT is open. If PT is closed, the hardware can be accessed by other software including Logic or Ableton.
The Mbox2 Pro I/O can, indeed, be used to interface outboard. However, be aware that the return audio will be subject to a degree of latency which you will need to allow for. The Mbox Pro does not come with DV Toolkit as standard. This is a paid add-on/option. http://www.myspace.com/philogg |
HDX multi-client? | Matts | Pro Tools 10 | 5 | 11-15-2011 12:18 AM |
Does Mbox 2 support Multi client? | djcreation24 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 04-24-2011 01:58 PM |
multi client? | Dipozit | Tips & Tricks | 8 | 11-04-2010 07:40 PM |
ASIO : Multi Client support for Mbox.....ever gonna happen ? | deejo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 04-30-2007 04:19 PM |
MBox 2 DirectSound-compatible multi-client driver | mattrog | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 04-27-2006 05:00 AM |
