Help with Dialog
Hey there,
I've been editing Dialog now for a few months, and am faced with inconsistent, low levels. I use the Waves Vocal rider, and a TC 6000 comp, and they work very well to establish a strong track. My problem is with the PT "Gain" plug in. I use this a lot to tweek the low spots...but it is time consuming...and when the "Gain" plug is open, I can't use some of the most common quick key strokes...so I am constantly opening and closing that little bugger... What are you all using to optimize dialog tracks? Thank you for the advice! Roger |
Re: Help with Dialog
How about normalizing the low level clips? I typically bus all dialogue to an aux with one or two trim plugin set to +12 and then ride the faders into the aux.
Ken Wilkinson http://kenwilkinson.tv Pro Tools 10.3.9 HDN | HD Omni | Digi Command 8 | Artist Transport | Digi Surround Panner | Blackmagic Intensity Pro | JBL LSR4328 5.1 2.26GHz 8 Core Nehelam 8GB Ram OSX 10.8.5 |
I use time adjuster short 24db gain, bullet proof autotion and 4ms delay - what's not to like?
cheers
cheers Mike Aiton BSc (hons) Audio Consultant, Dubbing Mixer/Sound Designer & Journalist BAFTA member IPS member ---------------------------------------------------------------------- www.mikerophonics.com |
Usually have a Waves R-Comp on each DIA trk, and use it's 30dB make-up gain to bring things up into range.
PT 9.03 w-CPTK / 003 Rack / 2 x 2.8 GHz Quad core Intel Mac / Blackmagic Intensity Pro / AlphaTrack / Faderport / MotorMix / Nocturn / BlueSky BMC MkIII |
I use Massey limiter L2007.
30db of gain and a clean limiter you can shave off the transients before hitting you dialog compressor. /Benny |
+1
You could also use the toggle floating windows plugin to quickly hide/reveal your AS Gain: cntrl+opt+cmd+w
----I was thinking of taking a solo in the bridge. -Nah, I don't think that would sound good. ----Ok, well how about just a series of cool riffs? Mac Pro 2008 (Harpertown) -- OS X 10.8.2 -- 16GB RAM -- WD Black Drives -- UA Apollo Quad -- Pro Tools 10 w/ CPTK |
Thank you all for the tips!
Fades Dialog Box Bug | mrsticks | Pro Tools TDM Systems (Mac) | 1 | 09-08-2010 10:16 PM |
Dialog EQ | Dallas Taylor | Post - Surround - Video | 3 | 04-28-2005 04:01 PM |
Mbox in Use Dialog | MacMonkey | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 04-23-2004 07:59 PM |
PT 6.1/6.1.1 dialog box | SKI | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 11-02-2003 09:39 AM |
dialog | AdamFrick | Tips & Tricks | 4 | 10-24-2000 02:38 PM |
