Old 04-21-2004, 10:40 AM
MacMonkey MacMonkey is offline
Default Mbox in Use Dialog
I'm running OSX 10.2 and Pro-Tools 6.2. Starting up pro-tools I get a dialog saying Mbox in use and it tells me to quit all applications. I quit all of my audio apps and it still doesn't come on. The only solution is to re-start my comp and go straight to pro-tools to open it.
anyone know how to change this so I can "plug-and-play"? I'm not sure if this is a core-audio problem but please send me your input.
Titanium Powerbook G4
867MHz
768RAM
OS 10.2.8
Running: PT, Reason, Live
Old 04-21-2004, 11:19 AM
Arvid TomaykoPeters Arvid TomaykoPeters is offline
Default Re: Mbox in Use Dialog
try going to digi coreaudio setup and removing all apps from the supported list that you do not absolutely need. Also try setting Built-in audio as the default in and out in Sound Preference pane. Hope this helps.
-Arvid
Squish the Squid Productions
Old 04-21-2004, 04:49 PM
MoreMeintheMonitors MoreMeintheMonitors is offline
Are you running JUST 10.2? or is it 10.2.something? If it's 10.2, then you need to update to at least 10.2.3, preferrably 10.2.8.
The other thing is that you say you're running Pro Tools 6.2. There is no version 6.2 and, more importantly, the latest version for any 10.2.x version of Mac OS X is Pro Tools 6.1.2.
Please check your OS version and Pro Tools version, make sure they're compatible and then report back.
Old 04-21-2004, 09:14 PM
Sorry.
OS X 10.2.8
Pro-Tools 6.1.2
This problem is really annoying because I DJ a lot live and I've gotten together enough of my own material to perform via my Tibook but say my screen or energy saver comes on and bam, I've got to re-start my whole machine to get things running again.
867MHz
768RAM
OS 10.2.8
Old 04-22-2004, 01:30 AM
Hazy Hill Hazy Hill is offline
I have an mBox too; I don't have any problems with screensaver but energy saver is not supported.
Ufuk Onen
www.UfukOnen.com
Old 04-23-2004, 07:59 PM
Any more suggestions? Thanks for all the help
867MHz
768RAM
OS 10.2.8
CPU Overload Dialog Box PT 10.3.8 FranciscoDrums Pro Tools 10 0 01-23-2014 06:26 AM
Help with Dialog Roger Stauss Post - Surround - Video 7 08-09-2011 08:27 AM
Dialog EQ Dallas Taylor Post - Surround - Video 3 04-28-2005 04:01 PM
PT 6.1/6.1.1 dialog box SKI 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-02-2003 09:39 AM
dialog AdamFrick Tips & Tricks 4 10-24-2000 02:38 PM
